slow acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2007, 06:31 PM   #1 (permalink)
View 87_camry's Photo Gallery
slow acceleration
I have just got my 1987 Canry 2.0 up and running but when I go to take off its real slow at accel.when goin up hills unless I go into low the 2 then drive I cant make it up them?what could and is the best Idea ya have for this problem?
87_camry is offline   Reply With Quote
Old 04-25-2007, 06:46 PM   #2 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
Welcome to the forum!
How many miles on your car? Does it start & idle alright? Any other symptoms? Give us as much background info as you can. There are MANY sharp people here on this forum, and the more info you can give, the more accurately they can diagnose the problem.
You said you just got it up & running.... what was the problem with the engine? Or was it just a few other general repairs to get it driveable?
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 04-25-2007, 08:52 PM   #3 (permalink)
slow acceleration
yea my bad man.it has 257805 miles and it starts just fine and idles just fine.no smoking out of the exhaust just sluggish acceleration and no power up hills unless you put it in low gear.its an auto on the floor.I recently put a new balancer,waterpump.time belt,rebuilt starter.the vacuum hose was disconnected but I reconnected that and still does it.I think it may be vacuum or egr or at least Im hoping.maybe a headgasket but Im not sure.Thanks guys
Old 04-25-2007, 08:54 PM   #4 (permalink)
slow acceleration
by the way the engine is a 3sfe it was built jan 1987 if this helps?
Old 04-26-2007, 03:44 AM   #5 (permalink)
View Kingdom934's Photo Gallery
Is it downshifting when you start pressing more on the gas?
Kingdom934 is offline   Reply With Quote
Old 04-26-2007, 08:18 AM   #6 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Look for restricted exhaust.
Doctor J is offline   Reply With Quote
Old 04-26-2007, 01:40 PM   #7 (permalink)
Gameroom cash: $302555
"I have just got my 1987 Canry 2.0 up and running."
How long was this car sitting? Was it any length of time? If so, does it still still have the original tank of gas in it that was sitting in the car all this time? Gasoline deteriorates over time unless a stablilizing agent like Stabil is put in the tank, and even then it will only keep the gasoline from deteriorating for about 1 year. Otherwise it can turn in to a varnish-like substance that doesn't burn well and can clog fuel injectors. I have a car that I store during the Winter months. One year I put it away in early November and didn't take it out of storage until mid May. It had a full tank of gas in it when put in storage. When first taken out of storage it ran poorly until that first tank was used up. I refilled the almost empty tank and the car ran perfect again. If your car was sitting with gasoline in it for any length of time I would refill the tank and run some fuel injection cleaner in it for the next couple of tanks.
Mike
Old 04-27-2007, 12:46 PM   #8 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I had a broken injector once that had a similar affect. Once I got up to speed I didn't notice it but accellerating from a stop was really wierd. I'm not sure but you might be able to pull your spark plugs and see if they all look the same. If one cylinder wasn't working I would think that plug would look different.
Kep
Old 04-29-2007, 04:39 PM   #9 (permalink)
View car_boy_16's Photo Gallery
Have your Catalytic Converter checked out, it may be clogged/melted/broken down/whatever. If so, I would buy a header for the car, that will help out with the power, and recheck the ignition timing to make sure it's not retarded too much.
1988 Camry LE 3sfe 4A - 123k miles
...Slower than a school bus!
car_boy_16 is offline   Reply With Quote
Old 05-02-2007, 10:53 AM   #10 (permalink)
View Variety=Spice's Photo Gallery
check your AT fluid level. change your AT fluid and filter.
Variety=Spice is offline   Reply With Quote
Old 05-05-2007, 05:07 PM   #11 (permalink)
View monito's Photo Gallery
how steep is the incline... i have a 1990 2VZ-FE AT, and on steep inclines, i have to use the ETC button to help climb steep hills [6% +]
monito is offline   Reply With Quote
Old 05-08-2007, 01:52 AM   #12 (permalink)
View thisismikey's Photo Gallery
91 camry 3s-fe
I have had my water pump replaced recently and dealing with the mechanics, I have learned that the timing belt is critical to my '91 2.0L 4 cylinder camry. The timing belt has to be removed in order to replace the water pump. If the timing belt is not put on exactly as it was before, then, there is definately an issue with slow acceleration in the first and second gear. My mechanic asked me if the car ran correctly after installing the water pump the first time. I said that it was very sluggish. He said that the timing belt must be off by one tooth and corrected it soon after that first test drive. It's a pain to go through, but, I'd be willing to bet that that is the problem if you are having acceleration problems after you replaced the water pump.
thisismikey is offline   Reply With Quote
Old 05-10-2007, 11:25 AM   #13 (permalink)
dsm = desert sand mica.
View 94dsm's Photo Gallery
id try cleaning the egr, i know im not gen 2 or 1 but im just pokin around. and i was having really really sluggish acceleration, so i took it off and it was almost completely blocked off from the intake i cleaned it out and it is a lot more responsive and giddy uppy
catbacked. miles keep pileing up quickkk!
94dsm is offline   Reply With Quote
22R Slow Acceleration Vasille 89-95 Toyota Pickup/Hilux 9 07-19-2006 01:39 PM
2003 camry v6 slow acceleration. OrangeJuice 5th & 6th Generation (2002-2006 & 2007-2011) 2 05-14-2006 03:50 AM
Slow acceleration with Higher RPM's camry98Green Camry & Solara Lounge 10 03-16-2006 05:14 PM
2nd/3rd Gearz Acceleration = SLOW on V6 chuson Camry & Solara Lounge 16 01-08-2006 08:15 PM
slow acceleration after 70mph infox Camry & Solara Lounge 19 12-26-2005 08:06 PM
