1988 camry EFI/ECU problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2007, 11:10 PM   #1 (permalink)
View MPrus's Photo Gallery
I have a 1988 Camry with 2.0 DOHC and Auto trans. The problem I have is the car will start, but only run for a few seconds. The code I got by bridging the efi terminals told me, acording to the haynes repair manual, that either 1.The efi relay was bad, 2. The main ecu relay was bad, or 3. The ecu had a problem. The two relays are good. I forgot to mention that the fuel pump only comes on with the key in the start position, not in the run position, and as soon as you release the key back to the run position, the pump shuts off again. Now, I tried running a toggle switched hot wire directly to the pump to turn it on, but that didn't work either, still just dies out after a few seconds. Any help would be appreciated. The code is two flashes of the check engine light.
MPrus is offline   Reply With Quote
Old 04-26-2007, 12:21 AM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
i would say check your IGN switch and ciruit first
atobe is online now   Reply With Quote
Old 04-26-2007, 08:21 AM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Is a code number 11?
Doctor J is offline   Reply With Quote
Old 04-26-2007, 10:08 AM   #4 (permalink)
Yes It is code 11.
Old 04-26-2007, 10:52 AM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
the service manual said code 11... wire severance in +b on ECU... areas to check.. IG switch circuit, main relay circuit, ECU
Old 04-26-2007, 11:18 AM   #6 (permalink)
And if neither circuits have faults does that mean I have to replace the ECU?
Old 04-26-2007, 12:32 PM   #7 (permalink)
Doctor J's Avatar
I would suggest to attach pos. probe of the digital voltmeter to wht wire with red tracer near ECU (there are 2 wires, so do one at the time), clip negative voltmeter probe to the good ground, then attempt to start the engine.If the engine dies while power is still present check the plug in connectors to ECU. If the engine dies and voltage goes to 0, download the electrical a wiring schematics and check.
The ECU seldom goes bad.
Old 04-26-2007, 07:34 PM   #8 (permalink)
Is there another way to access the diagrams? My computer isn't downloading them for some reason.
07 Camry SE V6 Problem - Service Dept. Stumped - Comments? kkmatuse 5th & 6th Generation (2002-2006 & 2007-2011) 61 06-27-2009 01:45 AM
Starting problem with my 99 Camry sdpais Camry & Solara Lounge 2 12-25-2006 12:55 PM
94' Camry Coupe V6 LE Engine Shut Off Problem farooqm78 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-20-2005 01:12 PM
99' Camry Start then dies Problem EBMCS03 Camry & Solara Lounge 6 08-30-2004 09:57 AM
