confirmed - have serviceable struts - but how to unscrew strut housing?!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2007, 12:09 AM   #1 (permalink)
View jtu100's Photo Gallery
Exclamation confirmed - have serviceable struts - but how to unscrew strut housing?!!
Ok, I've had it confirmed that I have serviceable struts, and I have bought at the front pair of KYB 365088 cartridges and a spring compressor.
But I have now realised I have no idea how to get the 8-sided nut on/off the top of the of the strut housing. It is about 55mm diameter and no wrench/spanner I know will fit on that.
What tool should I use for this?
Also do I need a special vise to hold the strut still while I use [insert tool name here] to undo the nut?
Lastly, how tight is this nut? I am hoping not too tight as I wont be able to get much torque on it I suspect.
Toyota Camry 1988, SV21, 3SFE, Station Wagon
Sydney, Australia
jtu100 is offline   Reply With Quote
Old 04-26-2007, 12:20 AM   #2 (permalink)
Also, is it easier to undo the strut housing nut while the strut assembly is still attached to the car?
Obviously I would need to attach the spring compressors whilst the assembly was still mounted to the car, otherwise the spring will fly off when I try to remove the assembly from the car...
Sydney, Australia
Old 04-26-2007, 12:30 AM   #3 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
you take out the whole strut/spring assembly as a whole... then you put on the spring compressor compress the spring.. that'll allow you to take off the top strut mount.. then you slowly/safely let out the spring with the spring compressor.. the strut mount willt take out your head if you don't have a spring compressor. then you take out the spring which would give you access to that big nut to remove the insert. then you do the whole thing in reverse...
http://www.autospeed.com/cms/A_2882/article.html read this first give you an idea for what you'r about to do
atobe is online now   Reply With Quote
Old 04-26-2007, 12:56 AM   #4 (permalink)
That guide only shows the springs being replaced, not the inserts being replaced which is what I'm doing.
I have also read 3 other guides (admittedly not for camrys) saying to loosen the top piston nut as the first step before you start the rest of the process. I can understand this because otherwise according the to the Toyota Service Manuals I need all sorts of SSTs to hold the suspension support whilst I undo the nut etc. Also need a vice which I dont have.
I fully realise how dangerous the spring is... I will be very careful dont worry!
Sydney, Australia
Old 04-26-2007, 03:47 AM   #5 (permalink)
Hmmm, I just had a go at removing the nuts on the steering knuckle.
Couldn't budge them. Was using a regular sized socket wrench. I could also see red paint on the bolt which presumably is some sort of glue. The service manual says these nuts are done up with 2200kg/cm of torque.
Presumably I'm going to need a massive (0.5M?) breaker bar to get these nuts off?
Do I need to reapply the adhesive when I put the bolts back on or is that overkill?
Sydney, Australia
Old 04-26-2007, 10:54 AM   #6 (permalink)
Pochacco Owns Me
atobe's Avatar
just re-torque it to spec and put some anti-sieze on them. i would say... have someone step on the strut as you try to turn the nut
Old 04-26-2007, 03:08 PM   #7 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Plumbers pipe wrench... careful putting it back on that you don't scratch the new strut piston.
-Charlie
Old 04-26-2007, 08:04 PM   #8 (permalink)
I do not have the torque spec in the Toyota Service manual as it does not show a serviceable strut in the manual!
Sydney, Australia
Old 04-27-2007, 04:20 PM   #9 (permalink)
white90dx's Avatar
Just tighten it up as much as you can.
-Charlie
Old 05-03-2007, 12:18 AM   #10 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
-Charlie
That's what I used also.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
not your usual strut question ryuji16 Camry & Solara Lounge 6 05-05-2004 02:08 PM
" K Y B " struts vs. Toyota/Lexus struts 93 Camry LE V6 General Discussion 6 12-13-2003 12:21 PM
Toyota/Lexus struts say "TOYOTA" & "KYB" on them. Thought they were differe 93 Camry LE V6 Camry & Solara Lounge 5 12-12-2003 11:19 PM
91 Camry struts EYE_AM_CRAZY 1st & 2nd Generation (1983–1986 & 1987-1991) 4 11-14-2003 12:08 AM
Sealed strut conv. 2 serviceable ? NOTSOFAST Camry & Solara Lounge 7 03-18-2003 06:46 PM
