Crap, where's the hose? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2007, 07:55 PM   #1 (permalink)
View nuron's Photo Gallery
I wanted to remove the EGR valve for cleaning but that bottom bolt was too hard to get to. Then I saw this:
Is that hose important? I can see the clean and dirty difference on the stem. But alas, I just took out the EGR vaccum modulator's filter thing and it was too dirty to do anything...
nuron is offline   Reply With Quote
Old 05-01-2007, 09:37 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
This hose connects A/C air control valve to the A/C idle up solenoid valve.With A/C on, the solenoid opens, so the manifold vacuum pulls the diaphragm up, that in turn opens a passage around the throttle plate which increases the idle speed. The solenoid is located on the firewall near windshield wiper motor.
The EGR vac. modulator could have ruptured back pressure diaphragm. therefore the vacuum signal may never reach the EGR valve.
Autozone store sells the new one for $57. I got one from 89 Tercel (junk yard) and it works.
Doctor J is offline   Reply With Quote
Old 05-01-2007, 10:59 PM   #3 (permalink)
So do I just get a hose and stick it somewhere or...?
Old 05-02-2007, 08:05 AM   #4 (permalink)
Doctor J's Avatar
You have to connect this empty port to the idle up solenoid.
Old 05-02-2007, 03:47 PM   #5 (permalink)
Alright, much thanks Doctor J I will get a hose from an auto place and report back.
installing oil pressure gauge help atobe Camry & Solara Lounge 23 09-18-2011 04:02 PM
Power Steering Pressure Hose [2VZ-FE] monito 1st & 2nd Generation (1983–1986 & 1987-1991) 27 01-23-2010 03:12 PM
What do you think: Bad hose or bad radiator? luiscolorado 3rd & 4th Generation (1992–1996 & 1997–2001) 4 02-08-2007 01:58 PM
turbo abew330 Supra Forum 0 02-07-2007 05:51 PM
Radiator Hose help. SubaruWRXMike Archived Corolla threads 9 05-06-2005 04:46 PM
