Do I really need a new gasket after throttle body clean? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2007, 01:17 AM   #1 (permalink)
View jtu100's Photo Gallery
Question Do I really need a new gasket after throttle body clean?
The service manual states a new gasket is needed after removing the throttle body. Same for the Idle Speed Control.
Is this true?
If so, is it best just to make your own? What material are they made from, and where do I get them.
Yours cheaply,
Jack
Toyota Camry 1988, SV21, 3SFE, Station Wagon
Sydney, Australia
jtu100 is offline   Reply With Quote
Old 05-03-2007, 01:47 AM   #2 (permalink)
ezkiel's Avatar
View ezkiel's Photo Gallery
dont be cheap, just buy them they arent expensive. they are usually made out of a paper/cork material. the most expensive gasket ive come across was a 1piece gasket for a oilpan off a 350ci. which was 40 bucks.. header gaskets were 20? these are simple nothing more then paper/cork type stuff, they will be like 5 bucks man..
2006 TRD Off Road Prerunner SR5
http://www.cardomain.com/ride/2628822
ezkiel is offline   Reply With Quote
Old 05-03-2007, 05:31 PM   #3 (permalink)
View marc780's Photo Gallery
jtu there's probably no need to remove the IAC, and definitely no need to remove the throttle body, just for a cleaning.
The only reason to remove the IAC is if it is being replaced with a new one, or the cleaning doesn't improve performance. If this were the case, chances are the problem is elsewhere in the system, and not the IAC anyway. If you do decide to remove the iac, do it carefully in case the gasket is still in one piece and usable. Some camrys have a neoprene gasket that uses no sealer, and i have reused these before and they worked. If the old gasket is torn or broken, or the IAC leaks or wont idle after you put it back together - then yeah you do need a new gasket.
During the cleaning you can generally just spray enough in the IAC hole to dissolve most of the crud, enough to make it work right again, and without disassembly. Use the whole can, use a rag to catch the excess that blows out. You can quit if you start seeing the excess cleaner blowing out of the IAC still clean, or you run out of cleaner. If that doesnt fix it, it's maybe time for new parts or another diagnosis.
http://www.toyotanation.com/forum/t157470.html
Old 05-04-2007, 08:26 PM   #4 (permalink)
NYR
View IvanHoe's Photo Gallery
throttle body gaskets are like 5 bucks
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Throttle body gasket !!!! help megamac83 3rd & 4th Generation (1992–1996 & 1997–2001) 5 10-30-2006 09:00 PM
Cleaned throttle body now it wont start.. green94camry 3rd & 4th Generation (1992–1996 & 1997–2001) 12 10-14-2006 12:21 PM
Q45 throttle body? Touge-MR MR2 Forum 2 01-14-2006 06:12 AM
how to clean throttle body EKam Hardcore Tech and Competition 9 07-29-2002 08:30 PM
