Speedo cable snapped? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2007, 09:25 AM   #1 (permalink)
View Spetz's Photo Gallery
2nd Generation Speedo cable snapped?
So, all of a sudden my speedo doesn't work
I assume the cable has snapped.
Just wondering how expensive these cables are, and how hard it is to change them?
Apparently the cable was changed about 15,000km before I bought it. Is it a common issue these cars have?
Spetz is offline   Reply With Quote
Old 05-11-2007, 09:46 AM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
odd. if its been replaced before, its could be the gear inside the transmission that the cable connects to. the cable itself is easy to replace, i dunno about the gear though. Look on the firewall towards the middle of the car and you can see the cable. it unscrews from there, then you can unscrew it from the transmission. Pull the cable out and see if the pin that goes into the transmission is still intact.
not sure how much a new cable is, but a junk yard should have plenty and would be cheap.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 05-11-2007, 10:54 PM   #3 (permalink)
And how would I isolate the problem?
ie, figure out where it went wrong/broke?
Old 05-12-2007, 12:09 AM   #4 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
interesting...never heard of this problem... i'd say the easiest way is take out the guage cluster and drive and see if the speedo cable is spinning.. if it is then your gauge is broken or some part of it is.. if it's not then it's probbly the cable... easiest way i can think of... unless you can have someone look at your tranny and see if the speedo cable gear is moving while you drive
atobe is online now   Reply With Quote
Old 05-12-2007, 10:50 AM   #5 (permalink)
Tommy's Avatar
the only place the cable would likely break is at the transmission side. just pull it out and see if the pin is there.
My garage
Old 05-12-2007, 11:06 AM   #6 (permalink)
NYR
View IvanHoe's Photo Gallery
My cable/speedo makes a slight noise when I drive.....kinda like keys brushing against the column
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 05-14-2007, 11:47 AM   #7 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The cable is easy to reach and is in two parts. There's a large knurled knob on the transmission and a joint before the firewall. I've never removed it from the back of the speedometer. I expect that the biggest hassle would be getting to it. However, if the problem is at the transmission it is easy to remove the cable but like said above, there may be an underlying problem that is causing the damage.
Ivanhoe, get some transmission cable lube and open the cable at the union. Squirt the lube in both ways and elevate the cable going into the firewall for a while to let the lube get up to the top. I left mine tied up overnight. After-wards it was like new.
Kep
Old 05-24-2007, 01:57 AM   #8 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
If you undo the coupler near the firewall and spin the cable to the spedo by hand it should jump a bit indicating the speedometer and cable to it are fine. I just did this to the AllTrac I just bought and now I know it has either a bad cable or the gear in the tranny is broke, only problem is I can't seem to get the lower cable loose from the tranny.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 06-03-2007, 02:15 AM   #9 (permalink)
Not so Noob now!
es250nut's Avatar
Update: got the speedo fixed. In the Alltrac there is a 90 degree cable adapter that comes out the back side of the transmission so the speedo cable can be screwed into it in a similar place as the other trannies available in the Camrys. In this case the adapter seized and caused a short shaft to shear off the keyed ear. After freeing up, cleaning and lubing the seized part I got a replacement shaft from Toyota for about $9.
Now the speedometer works and I'll be able to figure out what the gas mileage is on the Alltrac.
91 camry OD light blinking trd23 1st & 2nd Generation (1983–1986 & 1987-1991) 14 12-23-2006 09:30 PM
89 celica speedo cable leak--help tspieker Celica Forum 6 01-21-2006 11:33 AM
91 Speedo Cable Question johnr MR2 Forum 9 10-28-2005 08:15 PM
How to remove Speedo cable from cluster??? mhavoc 89-95 Toyota Pickup/Hilux 1 10-23-2005 04:25 PM
89 celica speedo cable leak--help tspieker Celica Forum 1 05-11-2004 08:45 PM
