First of all, this is my first post here. I've been reading previous posts about the power steering leak, but most threads unfortunately do not end with any conclusions. So, I am hoping that I hear from those of you who may have solved this problem in the past.
I am working on an 89 Camry 3SFE engine, USA built. I'm doing a bunch of repairs on the car but I won't get into that. The specific problem I am trying to solve is the power steering leak. Here are the specifics:
1. The fluid level keeps going down after only a few short trips.
2. I see what looks like power steering gunk on the passenger side firewall and on the power steering tubes, specially the high pressure tube with the banjo fitting.
3. Oddly enough, no sign of fluid on the power steering pump belt.
I've already got the pump out with the banjo and rubber tubes attached
. I disconnected them from the top and pulled the whole pump and the tubes out from under the car. I have the passenger side axle out so made taking out the pump a bit easier, but still a big pain in the neck.
The problem is that there is so much fluid every where, on the tubes, on the pump, on the side and firewall, and I can't figure out where the leak is coming from. Being the nucklehead that I am, I didn't try turning the steeiring wheel with the engine running and looking for leaks. Now that I have everything taken apart it's too late for that.
So again, based on previous experience what fixed the leak on your car? Was it the banjo fitting, the high pressure tube, the pump?
How expensive is the tube with the banjo fitting? Do you replace the whole tube as an assembly?
Since there is so much fluid on the firewall and the fluid level goes down so quickly, I personally think it's got to be the high pressure side squirting all over the place. But, why not any signs of fluid at all on the belt?
Sorry about this long post
, but I wanted to provide you with good information about the problem.
Your quick replies would be greatly appreciated as I need to get this car running again and out of my garage.
