OIL light is on, is my engine toast? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2007, 10:49 PM   #1 (permalink)
View PoR2GeEzCamry's Photo Gallery
A few months back, my 89 3sfe camry died. The oil light was on and my father proceeded to drive the car while the oil light was on not really knowing it was VERY bad to do so. He got to work, and said that he heard no wierd noises, or any signs of the car being low on power. At the end of the day he went back to turn it on and it turned on for 5 seconds then shut off, and ever since then the engine wouldnt start. I had my friend come over last weekend to diagnose it, and there was spark, and fuel, so he checked the timing belt and the marks were way off, so he adjusted the timing. After that was done i put the key in the ignition and turned it, and the engine started!! The oil light was on, and white smoke was coming out of the exhaust. I turned it off after running it for about a minute. I turned it on again and this time the engine ran for 30 seconds then died. Before it died, there was a knocking/ loud ticking noise coming from the engine. My friend thinks its the connector rod bearings. What do you guys think it could be thats causing the oil light to come on, and causing the engine to die shortly after beiing turned on? Could it be my oil pump is dead, and not sending any oil pressure to the cylinders? Or is it something far worse, and i have internal damage and my engine is a goner? Let me know what you guys think.
PoR2GeEzCamry is offline   Reply With Quote
Old 05-17-2007, 01:42 AM   #2 (permalink)
View Kingdom934's Photo Gallery
Is the oil levels okay? Was it checked before restarting the engine?
If the oil light is on even though the oil level is within the L and H, then it could be the oil pump as from what I heard when the light goes on, it means an issue with oil pump/pressure.
Kingdom934 is offline   Reply With Quote
Old 05-17-2007, 01:19 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
First, the motor is GONE. If you run a motor for more than a few seconds with the oil light on, you just ruined most of your bearings. The smoke out the exhaust sounds like you lost some parts in the head too. Time for a complete new motor.
I didn't see a mention of checking the oil level? Hmmm...
-Charlie
Old 05-17-2007, 01:56 PM   #4 (permalink)
View toyomoho's Photo Gallery
The light is set to come on if the oil pressure is below 5psi. The prudent thing to have done was to test the sensor and hook up an oil pressure gauge where the sensor was installed.
Given the oil light was on when the engine began making noise, the engine is likely damaged. In most cases the cost of repair is more then you would want to spend thus might find a good used engine to drop in.
Old 05-17-2007, 03:42 PM   #5 (permalink)
oil level is where its supposed to be, i replaced the oil before starting it. Im assuming the engine is damaged becasue of the white smoke and knocking, Could it be the connector rod bearings like my friend said? Time to look for a new engine, or car. How much am i looking at for a used engine?
Old 05-17-2007, 08:53 PM   #6 (permalink)
View car_boy_16's Photo Gallery
Yeah that sounds just like connecting rod bearings...you spun a bearing a two....or more
White smoke huh....coolant is leaking into the combustion chambers - I don't know what that has to do with oil starvation but it still is not good....
Like others have said, your motor is toast, do not drive it anymore unless you want to become stranded somewhere after it finally throws the rod and grenades your engine. I would either do a quick rebuild (new bearings, piston rings, seals, t-belt, water pump, head gasket...other misc gaskets...ect) or else buy a JDM 3sfe and do a t-belt job on that.
1988 Camry LE 3sfe 4A - 123k miles
...Slower than a school bus!
car_boy_16 is offline   Reply With Quote
Old 05-18-2007, 03:33 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Yes, the loud knocking sound is a giveaway.
Drain the oil and remove the oil pan. Look for chunks of metal or metal filings in the pan. You can also unbolt the rod caps and look at the bearings, rods, and crank.
Problem with replacing the bearings is that the rod(s) and/or crank could be damaged as a result of spun bearings. So you would also need to replace the rod(s) and/or have the crank machined depending on how bad the damage is.
Personally I wouldn't bother rebuilding. Cheaper and easier to just swap in another engine.
"Skoolin' the unlearned!"
Old 05-24-2007, 05:57 AM   #8 (permalink)
View jaduncan's Photo Gallery
The water is coming from somewhere. (blown headgasket,or cracked water jacket) Determine exactly what damage has been done BEFORE buying any parts if you decide to go that route as it may not be worth trying to fix.
Think I'd go with another engine instead of a rebuild.
Allen
jaduncan is offline   Reply With Quote
Toyota Stand on Synthetic Oil siennavan General Discussion 51 12-09-2007 09:00 AM
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 09:38 AM
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
H11 Headlights Burnes 5th & 6th Generation (2002-2006 & 2007-2011) 49 03-25-2007 09:03 PM
funny oil change docktortal33 2nd Generation (2005+) 7 08-08-2006 03:17 PM
