Info about Swapping in a manual for a 3s-fe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2007, 11:09 PM   #1 (permalink)
mk2-1jz's Avatar
View mk2-1jz's Photo Gallery
2nd Generation Info about Swapping in a manual for a 3s-fe
I've searched this topic a lot, but I still need some more information before i commit myself to swapping my A/T for an M/T in my 88 camry 3s-fe. Firstly i read that ANY manual tranny from a 4 cylinder camry from years 87-02 will bolt DIRECTLY to my 3s-fe with minor modification...this suprised me, is this right, and if so how minor are the modifications? Because i would consider swapping a tranny in from a Gen 3. Also, when doing the swap, is it possible to lift JUST the tranny out? I've lifted a 3s-fe before but with the engine and the tranny as 1. It doesnt look to me that JUST the tranny will come out, even after removing various things in the way, so my question is can i lift just the tranny out with an engine lift and leave the motor? Finally, would i be able to mix and match certain parts from 2nd and 3rd gen, things like the shift cables and the clutch master cylinder? also would a 90 or 91 or Gen 3 manual ECU work with my 88 3s-fe or should i be able to keep the stock ECU? I know for the Gen 2 almost EVERYthing is interchangable, what about the ECU?
thanks for any help and info you guys can give me,
Jamie
mk2-1jz is offline   Reply With Quote
Old 05-21-2007, 11:35 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
try now to write in a big block.....
yes any 4cly camry tranny will work..probbly mount's the biggest issue
no can drop it out with the car on jack stands
cables will be ok.. but the shifter has to be out of a gen2
gen3 has 5sfe so no won't work
ecu may be but the later model 90-91 did have new sensors so dunno
atobe is online now   Reply With Quote
Old 05-22-2007, 04:12 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
1. Tranny can be removed by itself, but I find it easier to pull the engine and tranny together.
2. To make it easy; get the shifter cables, clutch master cylinder, etc.. from a gen 2.
3. Leave the ECU alone. The wiring going to the tranny will have to be rewired. Mainly the wiring for the neutral safety switch which doesn't exist on a manual tranny.
http://toyotanation.com/forum/t85352.html
^ 2VZ-FE, A540E to E153 swap.
Not exactly what your looking for, but has good info and pics.
"Skoolin' the unlearned!"
Old 05-22-2007, 11:38 AM   #4 (permalink)
mk2-1jz's Avatar
Thanks a lot atobe and 88 LE, I read over Jetspeeds whole thread. I'm gathering info to see if I want to attemp this. It seems that it took Jetspeed almost a month to do his conversion. I heard it could be done in a weekend. I also dont have the 6, I have the 3s-fe and figure if I collected ALL the parts im going to need i would be able to acomplish it in a weekend. It seemed Jetspeed had to do some minor modifications to mounts and so on to hold the tranny, would this be one of the problems I may face if I do the swap or does the 3s-fe coupling manual tranny bascially bolt in? What do you guys think? Thanks a lot,
Jamie
Old 05-22-2007, 09:31 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
you are going to need a complete car to get your parts from
3SGE generation differences DodgeGarage Hardcore Tech and Competition 8 01-29-2012 04:16 PM
Matrix Service Manual, on hand, let me know if need info RAAMaudio 1st Generation (2003-2008) 4 07-17-2011 10:51 PM
the 5sFE Turbo Upgrade Info Zrain Celica Forum 25 08-14-2007 12:31 AM
PART 1: 3S heads revised allblackalltrac Hardcore Tech and Competition 4 01-15-2007 04:49 AM
arrgh, darn haynes manual with incorrect info slag Camry & Solara Lounge 11 10-14-2004 09:42 PM
