Originally Posted by 94E420
yeah the smoke is coming from the engine compartment. the first two batteries went dead. it also idles really wierd since this has been happening. all electrical stuff works (except what I already mentioned) except when you use electrical stuff it makes the car act wierd and at night things go dim.
Putting 2 and 2 together from what you have said, it sounds like the alternator pulley may be seizing. That would explain both the smell (belt trying to turn over a seized pulley) and why the batteries are going dead, along with why the car acts weird when you use electrical stuff-the alternator pulley siezes and just can't keep up with the electrical load put on it.
You can try two things here. You can take the car to a place like Autozone and have then check the charging system; they will do this for free. You can also remove the belt from the alternator pulley and see how the pulley spins by hand. It should spin fairly easily.
As for the loss of the first 2 fan speeds, you have a defective "blower motor resistor"; a dealer only part.
Good luck.
Mike
