The dealer might be able to pull up the bolt part numbers on their computer, call first.
Toyota uses 6, 8, 10, 12, 14, 16 mm bolt diameters with 1.0, 1.25, 1.25, 1.25, 1.5, 1.5 pitch accordingly. Use a stick or rod in the hole to find the bolt lengths you need. Then insert whatever bolts you have (including English) and see which fits the best. Then compare English diameter to metric and see what you have.
Metric bolts are now common at stores. If you are in the LA area there must an industrial fastener store that sells metric bolts. Check the Yellow pages and call around. Purchase a good Class of bolt, (bolt strength). The vendor can help you with this if you know the torque setting. Or take the info to the dealer.
A well equipped hardware store might have the bolts, not sure about the box stores that only stocks what sells in volume.
