91 camry bogs on acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2007, 06:33 PM   #1 (permalink)
View thug252's Photo Gallery
Here's the problem I have a 91 toyota camry 3s-fe 4cyl that my grandparents have given to me. They are the original owners and the car has 141k miles on it. So far, I have put a plugs, wires, cap and rotor and I have also loosened the fuel filter banjo nut to chech for pressure and have also checked for spark aswell. no when I first start the car it runs fine but when it warms up, it stalls and doesn't want to run and when it does run, it misses all the way to redline. Now so far I have also removed timing cover and checked the belt which is on time. Lastly, when I disconnect the TPS, the car Idle goes up and the car revs normally. what should I do next?
thug252 is offline   Reply With Quote
Old 06-01-2007, 01:20 PM   #2 (permalink)
View toyomoho's Photo Gallery
Could be the TPS has a problem. Download the details from the appropriate service manual at the link below. The manual has a proceedure to test the TPS.
http://oregonstate.edu/~tongt/camry
Old 06-01-2007, 01:46 PM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
What type of transmission is in the car?
Is the TP sensor three wire or four wire?
Is the engine bogs down only when car is in gear but rews free in the park?
Doctor J is offline   Reply With Quote
Old 06-01-2007, 03:32 PM   #4 (permalink)
View OBwan's Photo Gallery
My bet is the cat is clogged.
OBwan is offline   Reply With Quote
Old 06-07-2007, 01:35 PM   #5 (permalink)
View S2k-Takara's Photo Gallery
Maybe a silly question, but what does TPS stand for? (where is it? and what does it look like?)
S2k-Takara is offline   Reply With Quote
Old 06-07-2007, 01:35 PM   #6 (permalink)
Could it still pass smog with a clogged cat?
Old 06-07-2007, 03:03 PM   #7 (permalink)
Gameroom cash: $302555
It stands for throttle position sensor. It's a small sensor located on the outside of the throttle body, usually on the firewall side, that tells the ECU (computer) how far the throttle valve inside the throttle body is open.
Mike
Old 06-07-2007, 04:18 PM   #8 (permalink)
Kool, how do I know if I need to replace mine?
Mike
2002 - 2005 Toyota Camry review! Lexusfreak 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-27-2006 03:43 AM
91 Camry Radiator Question champ_168 1st & 2nd Generation (1983–1986 & 1987-1991) 2 08-15-2005 01:37 AM
91 Camry, What is it's value? pbrooks259 1st & 2nd Generation (1983–1986 & 1987-1991) 1 06-25-2005 05:46 PM
sickest 91 toyota camry out there - chopped top - custom paint - thundercat/tmnt ginathereality Introduce Yourself Here 32 08-11-2003 01:50 PM
Difficulity in Search for a/c topics on a '91 camry Mohamed 1st & 2nd Generation (1983–1986 & 1987-1991) 0 08-16-2002 10:36 AM
