lamp failure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2007, 08:58 AM   #1 (permalink)
View s1138's Photo Gallery
lamp failure
I've searched around, but haven't been able to find a picture of one.
I know mine has shorted, but I can't tell what i need to fix.
Does anyone have a picture of the insides of the box.
s1138 is offline   Reply With Quote
Old 06-03-2007, 10:08 AM   #2 (permalink)
View marc780's Photo Gallery
There's not enough information in your post for an answer.
Old 06-03-2007, 12:06 PM   #3 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
The Lamp failure module is tucked away under the left rear fender, it is a yellow box about 2 1/2 inches square and an inch or so thick. If a single element bulb is put in the dual element spot it will cause the module to burn out, so check you lightbulbs first before replacing it, otherwise you will end up replacing it again..
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 06-03-2007, 07:09 PM   #4 (permalink)
What I was looking for was a picture of the actual board inside the Lamp Failure box.
There was a piece that had burned, and I wanted to make sure it wasnt a resistor or anything that required something special.
Luckily I ran into a fellow Gen2 owner at Wal-mart today, and they let me take a look at theirs.
Turns out all i needed to do was solder a wire on there, now the brake lights work again.
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Rear Light Failure Indicator Lamp on a 2003 Camry nick rusche 5th & 6th Generation (2002-2006 & 2007-2011) 6 03-15-2006 09:04 AM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
lamp failure module??to convert my 92 to a rear of a 95-96?? bigpeterock29 3rd & 4th Generation (1992–1996 & 1997–2001) 7 06-22-2005 07:25 PM
96 LE tail lamp failure sensor location simonfck 3rd & 4th Generation (1992–1996 & 1997–2001) 2 04-06-2005 12:38 AM
