Today I decided was the day to replace the front Struts, being that the Passenger Side one was damaged, leaking oil and had a broken top mount.
Tools needed:
14mm socket or open/box end for top mount nuts and caliper bolts.
21mm socket for Wheel Lugs or whatever size for yours
22mm socket for lower strut bolts
22mm open end wrench
Dremel with fiberglass cutoff wheel
Torque Wrench .... 1/2" preferred
Breaker Bar .... 1/2" preferred
Socket Wrench
1/2" Extension 6-8" long
Large Flat Screwdriver
Pliers or Vise Grip
Bailing Wire
Floor Jack
2 Jack Stands
1 6 Pack
NO Helper
Mechanix Gloves ... they're GREAT
We'll start by using the Large Flat Screwdriver to remove the Wheel Covers and the 21mm Socket with your breaker bar or torque wrench to loosen the lugs on both front wheels. Should look like this ... hopefully with not as much brake dust.
Now get the car up on jackstands. I used a block of wood on the jack and jacked from the front swaybar mounts in front of the engine ... not sure if this is the recommended place but it didn't do any damage. Do one side then the other. Place the Jackstands along the rocker panel in the Factory Jack Points .... I didn't have a problem finding these ... they were well damaged on this 17YO car, I used a few short 2x4's to keep from further damagaing the pinch welds. Then remove the front wheels and it should look like this just with the strut still in.
Now unlock the steering wheel since you will need to move the steering back and forth. While you are here check the condition of your ball joints, outer tie rod end and bushings ... I found a really bad tie rod end on one side and destroyed control arm bushings on the side with the damaged strut. Use the 22mm Socket with the breaker bar and loosen the lower strut mount bolts. I didn't need to use the 22mm boxend to hold back on the nut but you might have to. You may have to swing the brake caliper out of the way to get your socket in there depending on the depth of your tools, you will have to swing it out of the way to remove the lower bolt. Use the 14mm to remove the caliper bolts and swing it out of the way ... get the bolt out and put it back in the other way to hold things together .... the bolt heads face the front of the vehicle, so be sure you put it back together the same or see my pictures later when I put it back.
Now take a rag and cover the driveshaft boot to protect it ... I forgot this step, but don't think I ruined the boots. Use the large flat screwdriver to walk out and remove the clip holding the brake hose to the strut. Move the hose coupler out of the way and carefully cut a slit in the metal with the Dremel and Cutoff Wheel .... don't cut the hose so pay attention or pay the parts store. Use a pair of plier or visegrip to bend the hose bracket ... top half back - bottom half forward ... just enought to get the hose out of there. Use the 14mm socket to remove the three nuts on the upper mount .... you may be able to skip the step if your mount is broken like one of mine was.
Now remove the two bolts on the lower mount and manhandle the assembly out of there being careful not to rip the axel boots. You must also be careful not to have the knuckle fall towards you too much or the axel will unseat itself from the hub. Since I was leaving the car overnight, I used bailing wire to tie the knuckle so it would not fall over and attached it like this.
Now you have one out .... and are allowed to remove the first one from the 6 Pack, cool off and then tackle the other side!
This is what my busted strut and top mount looked like, My poor Mechanix Gloves need a cleaning now after handling that dirty greasy oily mess.
Compared to the one on the drivers side that is still in seviceable shape.
And in the red box in this picture looks like there is a problem with my lower control arm bushing on the side with the busted shock (thanks katrina pothole). Hopefully one of the two or three other GEN2 members that are replacing their lower control arms or at least bushings will do a writeup before I tackle this one. While you have the wheels off ... take the mud flaps off, lots of dirt in there .... clean it up and put some wax on the paint to protect it.
Tomorrow I will be taking both of the assembly's to the auto shop to use the airtools and spring compressor there .... much safer than the spring compressors I have at home and trying to fight the top nut without the air wrench. So Far this has been very easy compared to the suspension swap on my NewBeetle which really needs to be done in the shop or at least with airtools becuase the assembly will not come out without top nut removal first.
Will continue after assembling the new struts.
