No ding-ding from headlights left on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2007, 04:10 PM   #1 (permalink)
View wiccanferret's Photo Gallery
My '89 Celica and '94 Corolla turn their headlights off when the key is removed and the driver side door is open. The Camry does not. Should it?
If it shouldn't, why doesn't it ding at me to turn them off? I'm going to run my batteries down one of these days...especially without having a real reason to turn the headlights off on the other two cars.
Oh, and the ding-dinger does work as it dings at me when I the keys are in but the door is open.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 06-13-2007, 04:29 PM   #2 (permalink)
View monito's Photo Gallery
interesting... My camry has the auto light kill function. Of course, my cam is an LE model. I think the base model might not have it.
monito is offline   Reply With Quote
Old 06-13-2007, 04:31 PM   #3 (permalink)
Gameroom cash: $302555
Every Camry I have ever owned has shut off the lights under these conditions. so I would say you Camry does have a problem. I would download the manual for your year (you don't give a year) and check the electrical wiring diagrams for the headlights.
Mike
Old 06-13-2007, 05:14 PM   #4 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
mine doesn't do that... do you have crank windows?? i don't think those have that feature
atobe is online now   Reply With Quote
Old 06-13-2007, 05:42 PM   #5 (permalink)
I had an 86 Camry DX with crank windows and it had the "auto off" feature.
Mike
Old 06-13-2007, 10:25 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
some camrys do not have it
Old 06-14-2007, 05:07 AM   #7 (permalink)
View SkycapChris's Photo Gallery
My 89 Camry LE has it.
SkycapChris is offline   Reply With Quote
Old 06-14-2007, 08:25 AM   #8 (permalink)
Er...okay then. On those whose Camrys don't have the auto-off feature, does it ding at you?
And it's a '90 base model, the only Camry in my sig.
Old 06-14-2007, 04:40 PM   #9 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
I've had a '90 DX and a '90 base, neither had auto-off, neither dinged (that I remember). The only door chime I get is with the key in the ignition in the 'ACC' or 'Lock' position with the driver's door open.
The auto-off is controlled by the "Integration Relay" that is not present on the base model and is not as complicated on the DX model. I've actually looked into adding it to the base model. I might try if I remember to grab one from the junk yard.
-Charlie
Old 06-14-2007, 06:38 PM   #10 (permalink)
Yeah, it would probably be worth it. Any idea how complicated it would be to add? Have you looked closely enough to see if there are plastic connectors just waiting for a relay, and where would it go?
Old 06-14-2007, 11:26 PM   #11 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
The integration relay is with the fuse box located behind the left kickpanel. I'm not sure if it would just plug into a base model wiring harness, but it should swap just fine from a LE to a DX harness.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 06-15-2007, 12:16 AM   #12 (permalink)
white90dx's Avatar
Yeah, if I was going to grab it from a junkyard, I'd grab stub harnesses so that I could compare and see the differences in directly. It's pretty hard to tell just from the wiring diagrams.
Really though, it isn't a big deal. In the 6 years I've had a Camry (the DX or the base) I haven't left the lights on... I want the slow-glow interior light!
-Charlie
Old 06-15-2007, 08:18 AM   #13 (permalink)
I'm mainly worried about it because I have a wife and two step-daughters that are likely to drive all three Toyotas...and the Camry is the only one that neither turns its own lights off or dings at you.
99 Corolla headlights only work as DRL tonyend 8th Generation (1998-2002) 7 10-01-2008 03:06 PM
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
Rear left spindle and front camber kit need to be replaced darksparkz 3rd & 4th Generation (1992–1996 & 1997–2001) 4 09-19-2006 10:29 PM
jdm headlights problem rjthebattousai Solara 1 08-25-2006 10:49 AM
93 Headlights simms 89-95 Toyota Pickup/Hilux 3 07-03-2006 11:14 PM
