The B+ fuse wire appears to only run to the ECM. The wire color appears to start out as White/Red and shift to White/Blue after going through a connector. It is possible this wire could have had its insulation melt and the wire become grounded.
The ECU also connects to items such as the air flow meter, water temp sensor, ISC valve, throttle position sensor, injector circuit, igniter circuit, air valve and 02 sensor among other things. It is possible a wire running to one if these circuits could have been damaged causing a short.
