Camry starts fine but stalls - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2007, 03:34 PM   #1 (permalink)
View Reload's Photo Gallery
My friend has a 1990 4 cylinder Camry. When he drove it the car started to sputter then stalled. He waited a few minutes and it drove fine for a couple of days. The car then did the same thing, this time the car wouldn't start until the next day.
Now his car starts fine, but if he drives it more than 15mph it will stall. If he floors it from a stop it will stall (but if he floors it while the gear is in netural it will work fine). I checked the codes and it shows a code 14 error. I replaced the igniter but it still does the same thing.
Does anyone know how to fix this. I did a search on code 14 and other people had similar problems but the fix was not posted. If you know how to fix it could you please post the solution?
Thanks in Advance
Reload is offline   Reply With Quote
Old 06-18-2007, 03:47 PM   #2 (permalink)
View wiccanferret's Photo Gallery
Well, personally, my first step would be to replace the plugs, wires, fuel and air filter.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 06-18-2007, 06:44 PM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Verify that there is a continuity for Igt and Igf wires from igniter to ECU.
Move the wire harness to verify that such continuity exists
Clean the mounting pad for igniter because it is used as a groung path
Is the car equpped with the TACHOMETER?
Finally, hook up the wir wth test light to the BLK-ORANGE wire to the igniterthe test light must be on as long as ign. on indicating that power is supplied to the igniter
Doctor J is offline   Reply With Quote
Old 06-25-2007, 08:36 PM   #4 (permalink)
View chester08's Photo Gallery
there are lots of possible causes why car stalls: bad fuel pump; bad oxygen sensor; fuel filters; low transmission fluid; weak spark - it would be best to check the those toyota auto parts to see if there's something wrong and if it needs a replacement. good luck
chester08 is offline   Reply With Quote
2007 Hybrid Camry In-depth Consumer Review phenderson Camry Hybrid 3 08-15-2006 06:57 PM
HELP '96 camry dies/low RPM's when starting, runs fine warmed up {GodlightSoul} 3rd & 4th Generation (1992–1996 & 1997–2001) 2 06-03-2005 04:44 PM
Camry starts and dies... Help? bighoe Camry & Solara Lounge 8 06-02-2005 01:14 PM
93 Camry, hard coold starts...help berso 3rd & 4th Generation (1992–1996 & 1997–2001) 1 04-05-2005 02:49 PM
TCI ANNOUNCES PRICES OF ALL-NEW 2002 CAMRY - F bondobondo 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-14-2001 12:48 PM
