Stuttering on start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2007, 12:21 AM   #1 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
Stuttering on start
My aunt has a 89 Camry V6 with 190k km on the clock. Recently the car started stutter when she starts the car. The tach jumps between 3-600rpm before it can idle properly at the 2k rpm for a cold engine. Its fine when its warm though.
EvoFire is offline   Reply With Quote
Old 06-20-2007, 08:41 AM   #2 (permalink)
View wiccanferret's Photo Gallery
Make sure the plugs and wires have been changed within the last 30k. Fuel filter might be slightly clogged too but working once it has fuel flowing through it.
Pull the negative battery cable for a few seconds to reset the car's computer.
If that doesn't work, report back.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 06-20-2007, 05:22 PM   #3 (permalink)
View toyomoho's Photo Gallery
Might check for a sticking IAC valve.
Old 06-20-2007, 06:22 PM   #4 (permalink)
EvoFire's Avatar
Plugs and wires have been changed in the last 10k, fuel filter was just changed a few hundred km's ago.
Will try the negative cable
what's a IAC valve?
Old 06-20-2007, 06:50 PM   #5 (permalink)
IAC is idle air control valve. Controls the air bypass around the throttle plate and thus engine idle speed. The unit is attached to the throttle body.
Old 06-21-2007, 02:37 AM   #6 (permalink)
EvoFire's Avatar
How do I get to it? I'm a complete noob. Took me 283745029375 hours to yank the air filter out on her car. Took me 2 mins to put it back together though.... weird
2001 Tacoma won't start HotRodd38 1st Generation (1995.5–2004) 6 11-12-2007 03:44 PM
stuttering and stalling with rough idle kurzawa Camry & Solara Lounge 0 08-20-2006 07:20 PM
Start and go ? I don't think so. Mike-in-WV 1st Generation (1995.5–2004) 30 08-01-2006 08:51 PM
01 Rough Idle, Stall, Hard Cold Start anr 3rd & 4th Generation (1992–1996 & 1997–2001) 0 05-30-2005 12:50 AM
Click sound from under the hood..won't start snobdrblinkchik Camry & Solara Lounge 10 08-22-2004 09:04 PM
