left turn signal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2007, 11:31 PM   #1 (permalink)
View smkdwnn's Photo Gallery
2nd Generation left turn signal
Everytime I use my left turn signal it squeals like a damn pig. No signal till it stops squealing. Any ideas?
smkdwnn is offline   Reply With Quote
Old 06-22-2007, 11:52 PM   #2 (permalink)
View toyomoho's Photo Gallery
Might try replacing the turn signal flasher unit.
Old 06-23-2007, 06:27 AM   #3 (permalink)
found it, thanks!
Old 06-23-2007, 11:01 AM   #4 (permalink)
Turn signal relay is located in the drivers side kick panel relay box. Should be the top relay in the box. The relay pulls out.
Old 07-04-2007, 09:59 PM   #5 (permalink)
2nd Generation
I got a new flasher from toyota, it doesn't squeal anymore but the left turn signal works randomly. Anyone ever change the switch in the steering wheel column for the turn signals?
Old 07-05-2007, 11:38 AM   #6 (permalink)
View wiccanferret's Photo Gallery
Mine does the same thing...I'll let you know if I figure it out before you do.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 02-22-2008, 06:20 PM   #7 (permalink)
geojumper's Avatar
View geojumper's Photo Gallery
Smile Turn Signal Fix
Had Identical problem develop this past month, used some contact lube and clean from Radio Shack sprayed into stalk as I worked it back and forth. Now only occasionally makes noise ..... must have been dirty or corroded as you suspected. George in Wisconsin
geojumper is offline   Reply With Quote
1998 avalon turn signal flasher rrtbill1 Introduce Yourself Here 0 02-19-2007 08:20 AM
Turn signal, flashers, brake light issues!! tommytacoma 1st Generation (1995.5–2004) 3 01-17-2007 08:11 PM
Left Turn Signal nitu_752002 Archived Corolla threads 4 06-30-2006 11:06 AM
Question Bulb Type for rear turn signal cman2000 Camry & Solara Lounge 3 03-24-2005 10:53 PM
Turn signal failing CorollaKen Camry & Solara Lounge 2 03-24-2005 12:26 PM
