Oil issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2007, 03:08 AM   #1 (permalink)
Gen2 Camry Lover
View jgcertified's Photo Gallery
Oil issues
Hello all, yesterday whenever my dropped below 2000-ish RPM my oil light would start flickering on and off.. My stepfather thought it may be a broken pressure sender, but I was talking to someone else later, and I pointed out that for the past month or so, at idle it had a squeak (Almost like a pulley with one bad bearing) that would increase in speed with RPM until it went quiet.. But it was getting louder
Apparently this is the sound of an oil pump beginning it's death..
is that right?
Engine is a 3S-FE
'90 SV21 Camry .. Sick
jgcertified is offline   Reply With Quote
Old 06-25-2007, 05:11 PM   #2 (permalink)
View toyomoho's Photo Gallery
Suggest you have a shop check the oil pressure or do it yourself using a cheap pressure gauge-ASAP! If the oil pump is going bad, driving with low or no oil pressure will damage the engine resulting in very expensive repairs or engine replacement.
If the sender is OK, the light being on means the oil pressure is under 5 lbs.
Old 06-25-2007, 05:50 PM   #3 (permalink)
Gameroom cash: $302555
Follow toyomoho's advice. Have someone (or yourself) replace the oil sending unit temporarily with an actual pressure gage. A shop should not charge too much for this diagnosis. If it's a bad sending unit, it's a cheap fix. If it does have low oil pressur, it is from a bad oil pump or bad engine bearings. Bad oil pump means the pump needs to be replaced. Bad engine bearings means a new or rebuilt engine, or rebuild your existing engine. If it is bad bearings, then it's time to take a long look at how much you want to invest in this car. In the meantime, don't drive the car until you determine what the actual problem is. You could have a bad oil pump and destroy the engine by continuing to drive it; changing a few hundred dollar repair in to a very expensive engine replacement.
We'll all hope for just a bad sending unit.
Good luck.
Mike
Old 06-26-2007, 05:30 AM   #4 (permalink)
Gen2 Camry Lover
For quite some time, when you start it cold, the oil light stays on for a good 6 second, accompanied by a loud banging knock from the engine, and if it's revved cold (i.e driven) it revs up just fine, but when you let go of the accelerator, and the engine starts to wind down, you can hear a faint but distinct bearing knock sound around 2400-2200 RPM
Old 06-26-2007, 10:05 AM   #5 (permalink)
View marc780's Photo Gallery
Unfortunately it sounds like your bottom end is wearing out Low oil pressure can be caused not only by worn oil pump but also by main bearings and rod wearings worn too much...- might be time for a new engine at this point.
Old 07-10-2007, 01:29 AM   #6 (permalink)
Gen2 Camry Lover
*update*
For some odd reason, it only happens when I have the sub in the back on (It's powered by a DC to AC inverter)
If it's off, it's all good, when it's on I start getting the oil light playing up at idle
Old 07-10-2007, 08:27 AM   #7 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Disconnect the inverter and remove the sub>You may have the AC current leakage.
Get mechanical gage and measure the oil pressure
With oil system problem, the low pressure light will be on more often when the engine is on normal temperature.
Doctor J is offline   Reply With Quote
Old 07-11-2007, 02:01 AM   #8 (permalink)
Gen2 Camry Lover
The inverter thing was wrong.. It hadn't been doing it so i went for a drive today, had to go somewhere.. only got half way
Turns out it comes on after extended idling and/or low speed driving (60-70 kp/h or less)
Today it didn't flicker.. Whenever the revs dropped below 1000 it came on and stayed on.. Ended up getting it home by just keeping my foot lightly on the acelerator 9Revs about 1400) where it would go off, but occasionally flicker on
Also, it only happens once everything is at operating temp
7AFE oil-burning knowledge pool Piloter 7th Generation (1993-1997) 13 02-29-2012 08:35 PM
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
Gage Swap - Oil Press sender issues... SuperRA 89-95 Toyota Pickup/Hilux 10 12-13-2006 05:18 PM
Losing oil and other issues Crimzon Camry & Solara Lounge 10 02-27-2005 12:54 AM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 12:36 PM
