Hey guys...
I've been trying to figure out what's up with the Evap system on my Camry for a while now (obviously not trying very hard though!
) and haven't found what's wrong. It seems that my gas tank gets pressurized after running for a while. Instead of sucking in fumes when I open the gas tank, it blows out (say, at the gas station or whatever). It also seems to have made the leak at the gas tank filler seal at the tank leak worse (right now, I just put in 5 gallons at a time to keep the level below that seal until I can replace it).
I hooked up up the evap system correctly (I think!) when I did the swap. The vacuum line to the motor sees manifold pressure all the time (checked with my boost gauge), and has a one way valve that only allows air to flow from the evap canister to the motor so no boost pressure goes to the tank. I think the pressure build up in the tank is from the fuel warming up while driving (fuel heating as it is pumped up to 40-60psi flowing by the engine then back to the tank).
Where else should I check for problems? I seem to remember my only Camry doing about the same, but I think it would suck air into the tank when the gas cap was opened? I still want to keep my evap system working (gas fumes around my car that blows fireballs = not a good thing!).
Anybody have any ideas? (I'm lookin' at you, Dr. J!)
-Charlie
