gutting a/c? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2007, 06:14 PM   #1 (permalink)
View stricular's Photo Gallery
gutting a/c?
Can anybody offer any tips on gutting the a/c on a 3sfe?
It has never worked(in the five or so years we've had the car), so I just have to assume that all the freon leaked out long ago.
I'd also like to shed any dead wieght, however minimal. I figure the whole system should wieght a good 30 pounds or so. After that I'm taking out that soundproofing crap from under the carpets, which should be another good ten pounds.
I am familiar with taking this stuff apart, but is there anything I will need to do to the wiring system in order for the enigne to run right? Will I need a different ecu or anything?
stricular is offline   Reply With Quote
Old 07-01-2007, 08:59 AM   #2 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
Have you tried recharging the A/C? I just fixed the A/C on the wagon, total cost was like $40 for a kit I got at Wal-Mart. Had the unit recharged in like 10 minutes. Would be a MUCH easier solution than removing the compressor. I assume it had been out of commission for a long time, as the car has 365k miles on it, and had never been retrofitted for the "new" refridgerant. It's been over a month, and it's still working great. I'd encourage you to give it a try.
I don't think you'd need a different ECU or any such thing. The only electrical involved with the compressor is the electric clutch, which you'd simply unplug from the compressor. If the compressor runs off a dedicated belt, it should be really easy to remove it. If it runs off a belt that also runs the alternator, then you'd have to get a belt for a non-A/C equipped model, if that was even available.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
A/C always on; bad dash switch? bad relay? How to Test? ladd2 Camry & Solara Lounge 8 05-01-2007 06:11 PM
1998 Avalon A/C Issues ignoreme 1st Generation (1995-1999) 2 04-11-2007 10:47 AM
No A/C, no power to compressor, help! pcfrog General Discussion 2 08-15-2006 07:09 AM
A/C Not blowing Cold Air garrand3006 Archived Corolla threads 4 08-09-2006 04:08 PM
