Timing Question for Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2007, 04:03 PM   #1 (permalink)
View 5150gsd's Photo Gallery
Hello, I have another question that maybe somebody can help me with. 88 Camry LE 4 cylinder automatic. When you're using the timing light, this particular one is and Inductive Timing Light with the dial on the rear that you can adjust from 0-60. My question is after I jump the bridge terminal T and E 1 do you put the timing light setting to 10 and then adjust the distributor until the notch on the bottom pulley lines up with the 10 mark on the motor? Or, do you set the timing light to 0 and then adjust the distibutor until it lines up to 10? I'm not quite sure how to use this light.
Thank you.
5150gsd is offline   Reply With Quote
Old 07-01-2007, 04:32 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
jump the terminals like you did... and turn the distributor till it reaches 10 BTDC .i'm not sure what to set the gun to
Old 07-01-2007, 11:14 PM   #3 (permalink)
View scribby's Photo Gallery
I set mine to 0, then adjust the timing.
scribby is offline   Reply With Quote
Old 07-01-2007, 11:18 PM   #4 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
Set it to 0
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 07-01-2007, 11:58 PM   #5 (permalink)
View drugal's Photo Gallery
You can do it two ways:
1 - Set the gun to 10 degrees, and line up the pulley with 0 degrees
2 - Set the gun to 0 degrees, and line up the pulley with 10 degrees (probably the best way)
Tip: put some whiteout (for paper) on either side of the notch in the pulley. Makes it tons easier to see.
1987 SV21 3S-FE
1990 SV21 3S-GTE RC
drugal is offline   Reply With Quote
Timing question 89yotatruck 89-95 Toyota Pickup/Hilux 2 04-10-2007 06:37 AM
Tercel 1992 Timing Belt - Urgent Question svyatets Tercel, Paseo, Starlet, and Sera Forum 3 12-25-2005 01:47 PM
timing belt question camrydarkstar Camry & Solara Lounge 1 01-27-2005 04:54 PM
87 camry timing question... Ryanrusden 1st & 2nd Generation (1983–1986 & 1987-1991) 1 01-22-2005 12:11 PM
timing belt follow up question... BobES300 Camry & Solara Lounge 7 01-03-2005 10:04 AM
