Sunroof power - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2007, 11:30 PM   #1 (permalink)
View Paradigm69's Photo Gallery
2nd Generation Sunroof power
I have a 1990 camry with a power sunroof. It doesnt work and i would like it to. i cant seem to find any info. Any one know where the fuse is ?
thanks Daniel
Paradigm69 is offline   Reply With Quote
Old 07-06-2007, 11:04 AM   #2 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
It shares a 30Amp circuit breaker with the power windows & locks, which is located behind the drivers side kickpanel. You are more likely to have other issues other than a fuse/circuit breaker with your power sunroof if your power windows work.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 07-08-2007, 07:25 PM   #3 (permalink)
Canada
Thanks for the response , The wierd thing is that all the interior lights by the sunroof swith are dead to.
Old 07-11-2007, 12:01 AM   #4 (permalink)
Not so Noob now!
es250nut's Avatar
Could be the ground. Pull the bulb and use a multimeter to check if you have ground on one leg of your bulb circuit when it is in the on position.
Old 07-11-2007, 12:27 AM   #5 (permalink)
View toyomoho's Photo Gallery
Download the wiring diagram from the link below. Could be a lot of issues, bad switch, relay, wiring, etc.
http://oregonstate.edu/~tongt/camry
Why more power? 02TAC 1st Generation (1995.5–2004) 7 11-30-2006 10:40 PM
Splice/Tap Power - 2005 Camry MrRedPants 5th & 6th Generation (2002-2006 & 2007-2011) 0 11-04-2006 03:41 PM
Power Door locks on a 07 Yaris digink Yaris, Vitz and Echo Forum 2 10-29-2006 08:37 PM
Sunroof problems zeke General Discussion 1 07-14-2004 04:03 PM
