1987 overheating - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2007, 12:37 AM   #1 (permalink)
View Montanahelp's Photo Gallery
1987 overheating
I have a project car (4 cylinder) that it running hot. At highway speeds it hovers around the mid point range on the gauge, but the gauge wants to climb after about 15 miles. If I turn the heater on it cools to the mid point on the gauge at highway speeds. The slower I go the hotter it runs. It jumps to the high side very fast. ITS STRANGE HOW THE GAUGE REACTS SO QUICKLY. I have replaced the water pump, and today the thermostat, but it still runs hot. I thought the gauge wasn't working properly, but the water was boiling when I parked it after about.40 miles. Both cooling fans are working, Tomorrow I am going to swap the radiator with one from a parts rig. I don't have any steam out of the exhaust pipe or any moisture in the oil.
Montanahelp is offline   Reply With Quote
Old 07-07-2007, 08:41 PM   #2 (permalink)
Gameroom cash: $150200
View 66conv6's Photo Gallery
I had a similar problem in my 88. It was a POS (previous owner syndrome). New radiator for $120 solved the problem. Also I use Toyota hoses, water pump and thermostat as they are better quality then aftermarket. Now can't get number 2 fan for A/C to come on most times. Temp gauge goes way up in city traffic (110 degree heat) with A/C on.
66conv6 is offline   Reply With Quote
Old 07-07-2007, 08:58 PM   #3 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
check your thermostat ... may be also time for a coolant flush
Old 07-07-2007, 10:27 PM   #4 (permalink)
View Kingdom934's Photo Gallery
Sounds like the coolant is going bad. Drain and flush it. 50/50 mix if it isn't the 'premix' coolant.
Kingdom934 is offline   Reply With Quote
Old 07-08-2007, 11:19 AM   #5 (permalink)
Gameroom cash: $302555
I have to agree with 66conv6. Sounds like a partially clogged radiator. It can cool the engine under light duty conditions, but when that extra heat is added to the engine by driving at sustained highway speeds, it can no longer adequately dissipate the heat produced. This is the most common cause of the symptoms you describe. I would try that other radiator you have, if you are sure it is good. You might want to take that second radiator or the radiator on the car now in to a radiator shop and have it flow tested.
Mike
Mike Gerber is online now   Reply With Quote
Old 07-11-2007, 02:38 PM   #6 (permalink)
View toyomoho's Photo Gallery
If the heater cools things down and its use is required at hwy speeds, the radiator has very little extra cooling capacity. Could be plugged, inside or out. Is the air dam in place below the radiator (if this car has one)?
Old 07-13-2007, 11:49 AM   #7 (permalink)
I changed the radiator with a used one that I had. It was running cooler, but the gauge climbs when I slow down. I unplugged the fan temp sensor (mounted on the thermostat housing) which makes both fans run all of the time which helps, but it is just a bandaid. So far I have changed the thermostat, waterpump, and radiator.
When I turn off the car after being up to temperature, I can hear the radiator bubbling.
Another thing is that when I drive from a cold start it it gets up to normal opererating temperature within 2 miles. It seams way too fast to get to temperature.
I'm afraid I have a headgasket bad. How can I tell if that is the case?
Old 07-13-2007, 02:04 PM   #8 (permalink)
If there's bubbling, there's air in there.
Bad headgasket symptoms are usually the milkshake sludge under oil cap, Smokey exhaust (not to be confused with morning smoke), and it is eating coolant.
Old 07-13-2007, 04:10 PM   #9 (permalink)
I agree there might be air in the cooling system. Try a thorough bleeding of the system. Raise the front of the car slightly (the slightly raised incline of a driveway should be sufficient) and then remove the radiator cap. Now start the engine and let it idle for 45 minutes to 1 hour. You should see some bubbles rising through the radiator neck.
Mike
Old 07-13-2007, 09:07 PM   #10 (permalink)
Pochacco Owns Me
atobe's Avatar
or you can just run the car w/o the rad cap for a few mins with the heater on full blast that should bleed the system...make sure there's hot air comming out though.
1987 overheating when using A/C woob 1st & 2nd Generation (1983–1986 & 1987-1991) 6 04-30-2006 04:30 PM
Please help newbe !!!!! 92 camry V6 overheating vinniekhosla 3rd & 4th Generation (1992–1996 & 1997–2001) 1 07-06-2004 03:27 AM
Help!!!! New to Toyota Nation, Camry Overheating vinniekhosla Introduce Yourself Here 2 07-06-2004 03:03 AM
Overheating 1987 Camry WalterK 1st & 2nd Generation (1983–1986 & 1987-1991) 6 06-27-2004 06:13 PM
