Heres some other ideas to add to the pile...
how many miles on this engine? You didnt say but i'm guessing alot. I'd start with the basics:
1. Do a compression check on a warm engine. if compression is low, its time for a valve job, maybe rings, an in car overhaul to perform same, or another engine.
2. Fuel injectors can cause lost power as the other fellow says but if one or more is broken it will also usually idle very badly, and this is a tip off. If your compression turns out to be high and the engine mechanically sound, might be worth a try to have the injectors ultrasonic cleaned or replace them.
3. Exhaust system could be very badly restricted. maybe the catalyst is plugged, muffler baffles collapsed inside, etc.
4. Auto or manual trans? You didnt say! so I'm assuming auto. Because if you have a manual trans, maybe you just need a clutch?
