Camry 1990 SE leaks the coolant or water... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2007, 08:02 AM   #1 (permalink)
View ambi's Photo Gallery
Australia Camry 1990 SE leaks the coolant or water...
Camry 1990 SE leaks coolant or water, I have changed the pipe and all then i got to see that there is a small hole looks like a overfloer in the bottom of the waterpumb area (not sure the spelling guys) that is leaking out coolant/water whole day today it has been free the radiator guys. I need to know is it that hole is the overfloer or need to be shut ?
3SFE engine Automatic.
Check the pic.
http://images6.theimagehosting.com/radiatorleak.gif
2days before serviced, b'cos of this problem still hum...
what's yor ideas guys ?
Melbourne Motor Show Pics
{._.} Toyota Camry SE 1990 Sedan {._.}
._. ambi or Senseen or Senthu ._.
ambi is offline   Reply With Quote
Old 07-10-2007, 03:04 PM   #2 (permalink)
Gameroom cash: $302555
Could what you are describing be the hose that drains condensation out of the car when the A/C is on? If so, this is normal. I have seen people who are not that knowledgable about their cars mistake this for a water leak.
Mike
Mike Gerber is online now   Reply With Quote
Old 07-10-2007, 07:22 PM   #3 (permalink)
Australia
Mike
Well winter here in Melbourne, even i dont on the heater as well. just normal. I think there is a hole check the pic above I am going to add.
Old 07-11-2007, 03:43 PM   #4 (permalink)
There is usually a weep hole in the bottom of the waterpump area. It allows coolant to escape when the internal seal inside the waterpump goes. If that's what is leaking, the waterpump needs to be replaced.
Mike
Old 07-11-2007, 11:42 PM   #5 (permalink)
Thumbs up
Mike
Thank you Mike for the reply. I'm going to change the waterpumb, seal and time chain too.
Thanks again.
Gen 3 I4 Radiator Change/ Thermostat Change RningOnFumes 3rd & 4th Generation (1992–1996 & 1997–2001) 54 10-22-2011 02:35 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
1990 camry 4cyl-oil leaks swbtmis 1st & 2nd Generation (1983–1986 & 1987-1991) 3 10-22-2004 05:27 PM
