A/C Sensor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2007, 05:21 PM   #1 (permalink)
Wannabe Noob
Rasco's Avatar
View Rasco's Photo Gallery
A/C Sensor?
I just replaced the A/C System in my 89 Camry 4cyl. New Compressor, Reciever/Drier, Fans, R134a Conversion, Fully Charged with no leaks.
The car blows super cold air no problems but only after a couple of days. It seems like the compressor only kicks on when it wants to. So at times it doesnt blow cold air at all. The a/c light is still green tho.
Is there a sensor that I need to replace? Maybe a relay? Where can I check? Any help is appreciated. Thanks.
Rob
Rasco is offline   Reply With Quote
Old 07-11-2007, 08:42 AM   #2 (permalink)
View WVU91Camry's Photo Gallery
If you don't mind me asking, how much did you pay for all that? I think that's the next step for me too....
WVU91Camry is offline   Reply With Quote
Old 07-11-2007, 01:57 PM   #3 (permalink)
View toyomoho's Photo Gallery
Was the system evacuated of all moisture, the evaporation valve can freeze up otherwise causing intermediate cooling? It is normal for the compressor to cycle on/off. Is the car being keep cold or is warm air coming out inbetween the cold air cycles?
Old 07-11-2007, 11:41 PM   #4 (permalink)
Wannabe Noob
Rasco's Avatar
I bought all the parts online for $250 and I had a mechanic friend install them for $200. Other shops quoted me around the $1000+ range just for repairs.
The A/C system was completely evacuated. And there were no leaks detected.
The car's a/c ran Ice Cold for a couple of days. And Man it felt good! But now The compressor isn't kicking in anymore. Im thinking it may be electrical or a faulty relay.
Is there some kind of sensor or switch that activates the clutch on the compressor?? The system is fully charged with R134a and there are no leaks when we tested it out. And The only A/C relays I found were under the hood.
Old 07-12-2007, 11:01 AM   #5 (permalink)
View typesix's Photo Gallery
If no AC at low rpm, it may be coincidental, there is an idle-up valve on firewall on passenger side that produces a small vacuum leak upon receiving an electric signal and speeds the idle up. When rpm sensor detects increased speed it will engage the compressor. There is a sensor on the compressor that measures rpm and it should measure 100-130 ohms resistance at 68 F.
typesix is offline   Reply With Quote
Old 07-12-2007, 01:32 PM   #6 (permalink)
Could you PM me where you purchased that stuff?!? Best I could find is $430 for the compressor alone.
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
92 Celica ST - After 1 year of not driving A/C does not work Guitarlp Celica Forum 5 07-05-2007 03:46 PM
A/C always on; bad dash switch? bad relay? How to Test? ladd2 Camry & Solara Lounge 8 05-01-2007 06:11 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
