3 power windows dont work, driver works, all others motors work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2007, 01:32 PM   #1 (permalink)
View aleks77's Photo Gallery
Gen1 3 power windows dont work, driver works, all others motors work
hey guys just bought an 85 camry, it has power locks, power windows, power sunroof. The driver window goes up and down, doesnt go down automatically like its supposed to tho, and also the other windows dont go up or down at all, but when you apply direct current to them, the windows do go up and down, so the motors are fine, i think its something electrical? or maybe a fuse? i checked and all fuses look good tho. Any help is really really appreciated!
1985 Toyota Camry, 270,000kms.
aleks77 is offline   Reply With Quote
Old 07-15-2007, 01:35 PM   #2 (permalink)
not sure if this is all related, but the cig lighter doesnt work, and also sometimes when i have the headlights on at night, the instrument cluster goes off by itself. And also sometimes i put on the blinker and the whole gauge cluster blinks with it.....same thing happens when i hit the brakes, this doesnt happen often but does every now and then.
Old 07-15-2007, 08:05 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
come again?
Old 07-15-2007, 11:55 PM   #4 (permalink)
View nutyysqirrels's Photo Gallery
ok if ya chek the door jam you might find the problem with the windows this is where i found my similar problem .the wires had broken . as far as the lights on the dash .
check for coroded wire perhaps in the chargin system . im thinkin that the car might not be able to keep up with itself . thats just my first thought though.
nutyysqirrels is offline   Reply With Quote
Old 07-18-2007, 02:54 AM   #5 (permalink)
I checked the door jambs, all look good, is there a fuse that could have gone? I also found 1 harness clip disconnected, but cant find where to connect it to, its in the kickpanel, ill take pics.
Old 07-20-2007, 01:21 PM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The disconnected clip is the most likely problem. After that I vote for a broken ground wire to the drive door switches. Find the wiring diagram in the manual and start tracking down the wires in the driver door. Establish which are grounds (I believe that there are at least two) and run a temporary ground straight to the harness. If that solves it then you need to reroute a ground through the rubber hose near the hinges (a pain but it can be done). If not you will need to start running resistance checks from each switch to its corresponding motor. However, the fact that so many are messed up leads me to believe that it is a problem common to all of them.
Let us know!
Kep
Old 07-23-2007, 01:28 AM   #7 (permalink)
i dont have a manual, this is my beater, but its freaking hot out and i would like to get my windows working lol i cant open any window except the driver one, not only at the driver window control, but even at the individual windows.
Old 07-24-2007, 11:39 AM   #8 (permalink)
should i be lookin for wires that are literraly ripped appart? ill take a pic of the clip, i found a total of 3 now that are disconnected, not sure why?
Old 07-24-2007, 10:04 PM   #9 (permalink)
View rhwjaxfl's Photo Gallery
2nd Generation Need a manual?
Great site for manuals...... www.camrymanuals.com
rhwjaxfl is offline   Reply With Quote
Old 07-25-2007, 10:35 PM   #10 (permalink)
View marc780's Photo Gallery
Sounds like a switch. Does it have a child proofing switch on the drivers door? Change it. bypass it to check it, if it fails change it. I'd go junkyard.
No power to power windows shaunrichard Celica Forum 5 04-26-2007 10:42 AM
power windows help! nacho_nismo General Discussion 4 08-15-2004 07:51 PM
Gen 2 newbe help with power windows ekimllonk 1st & 2nd Generation (1983–1986 & 1987-1991) 3 07-18-2004 02:18 AM
Making some cool power (caution! For reference use only ) AngryAE101 Archived Corolla threads 5 11-03-2003 10:03 PM
my old '91 Camry LE power windows are busted... help! nekz 1st & 2nd Generation (1983–1986 & 1987-1991) 0 07-03-2002 09:42 PM
