slight engine knock - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2007, 09:31 AM   #1 (permalink)
View nogard's Photo Gallery
slight engine knock
I changed the oil in my '88 3S-FE camry, then drove it out to the driveway and parked it. It sat for two weeks with out being driven. When I started it there was a slight knock, sounded like a crank knock and not the usual valve train tick.
I shut it off check the oil level, it was good. Then I restarted it, only would knock with higher than idle engine speed. So I let it warm up and idle for a while, I can't hear it from inside the car, but when I have the hood open and in the enigne compartment, I hear it slightly, with higher rpm.
I never checked this before under the hood, so I have nothing to compare it too. But from in the car is now sounds normal. Should I be alarmed? Is there something else I can do or check. I have the same oil and filter that I always use, I've had this car for a year, and changed oil on it 5 times. I've changed oil many times, I don't think it is anything I've done, I think it is from the long time it sat.
I don't want to drive it and wrech something further if there is a problem. Please let me know what you guys think, or if any of you have experienced something like this.
Thanks.
nogard is offline   Reply With Quote
Old 07-16-2007, 09:40 AM   #2 (permalink)
View wiccanferret's Photo Gallery
Mine does that at lower RPM's. It usually fades off as the car warms up, and only does it if it's been sitting for a while. I don't know if that helps you at all.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 07-16-2007, 10:41 AM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
its piston slap
Old 07-16-2007, 07:23 PM   #4 (permalink)
Thanks for the feedback guys. After I let the car warm up it seemed to "fade" as you say. Later in the day I took the car into town, 30 min round trip, and it didn't make any unusual sounds. I think it was just a fluke from it sitting.
Old 07-16-2007, 07:30 PM   #5 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
It could also be a sign your main bearings are getting worn. I've had this happen to a few of the 3sfe's. They seem to make it about 20 to 30 thousand miles more before they become toast.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 07-16-2007, 07:43 PM   #6 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
Our wagon does this as well, has a pretty healthy knock when you first start it. Will see if we can make it go another 35k and hit 400,000.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Old 07-16-2007, 09:24 PM   #7 (permalink)
View Kingdom934's Photo Gallery
Are you planning to replace the engine when it does die?
My Gen1 2se engine used to had this odd 'tapping' noise on the top of the engine upon startup about 7 months ago. After I would change oil, it would be fine until after 1.5~2 months, then it would start again. Since the car had been running a bit long from oil changes before I started to do oil changes (before my uncle used to do it...and not on a strict 3month/3,000miles...more like 4 months), I started a every 2 weeks oil change with 10-30w HM then to 10-40w HM oil since I found a bit of 'sludge' like black crystals in the dip of the oil drain plug (at lease I hope it was sludge and not metal shaving). Since of that, I continued using 10-40w HM half syn oil every 2 weeks until 2 months ago when I finally switch to 10-40w HM full syn and now replacing oil every 1 month or every 2~3 gas fillup. Since then from the last 5 months or so, the car has not had no knocking/tapping noise from the religous oil changes i've been doing. Also changed the filter every time since they are only about $4 bucks anyhow.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 07-17-2007, 07:45 AM   #8 (permalink)
that is the strange thing, my car has low miles for its age...160,000. I don't know how it was treated before I got it, as far as oil changes go.
Old 07-17-2007, 09:49 AM   #9 (permalink)
I guess mine does too, then. 164k miles. I'm going to change the oil on it this weekend or before...I'll let you know if the tap goes away.
Old 07-17-2007, 05:33 PM   #10 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
there is a tsb on the 3s for piston slap
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
20r Engine Rebuild From Hell! nwdetectorist Off Topic 6 10-20-2007 09:19 AM
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
