3SFE- headgasket- Replace gasket or engine??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2007, 10:47 AM   #1 (permalink)
View Montanahelp's Photo Gallery
I have a 87 3SFE that is drinking water - I definately am blowing it out of the tailpipe. The engine has @ 165K on it, and has good power. When I bought the car the waterpump was totally gone, and I know it had been run very hot. I'm trying to decide whether to replace the head gasket (which I have never done before) or put another engine in it (I have never put a engine in one). I have an extra engine from a rolled Camry.
I'M ON A VERY LOW BUDGET WITH BOTH TIME AND MONEY.
Would you guys try the headgasket or just swap another engine in it? Are the 3SFE heads prone to excessive warping or cracking?
Montanahelp is offline   Reply With Quote
Old 07-19-2007, 03:16 PM   #2 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
If it were me, I'd do the swap. Provided you know the engine from the rolled car is good that is.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 07-20-2007, 09:04 AM   #3 (permalink)
Gameroom cash: $302555
You did say the current engine has good power. Does the current engine use much oil? If it were me and the engine wasn't using much oil, I would download the manual for your generation (they are stickied at the top of the General Camry forum) and follow the steps to do the headgasket. It really won't cost you much money, only some time, and would be a good learning experience. If you go through the trouble of swapping the other engine in, this engine is just junk anyway, so you have little to lose by doing the headgasket, IMHO.
Mike
Mike Gerber is online now   Reply With Quote
Old 07-20-2007, 10:20 AM   #4 (permalink)
the engine does have good power. It leaks a little oil, but I havn't put any time into fixing the oil leaks until I get the cooling system issues taken care of. I hate to pull an engine that runs so strong. THanks for your comments
Old 07-20-2007, 08:47 PM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
how much oil...mine leaks oil too but my mech told me not to worry about it.. i always poor back out almost 4quarts every oil chance so it doesn't bother me
Old 07-20-2007, 10:01 PM   #6 (permalink)
I haven't had the car long enough to know the oil useage. I've put about 600 miles on the car and it has used about 1/3 or a quart of oil, and about a gallon and a half of water Lets just say it is leaving multiple oil drops in my employers parking lot everyday. The oil inside of the engine is staying very clean. I figure the oil leaks are valve cover related.
Is 88LE still around in this forum?
Old 07-25-2007, 10:42 PM   #7 (permalink)
View marc780's Photo Gallery
You already have another engine ready to go? If you are sure its good, i wouldnt fool around, just put that one in. It will take you a day or three to do this but you can keep your old engine and fix it, on an engine stand, at your leisure as money becomes available, if you want.
If you plan on driving this car forever, then its not a bad plan to have a spare engine ready to drop in again if you have to.
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
20r Engine Rebuild From Hell! nwdetectorist Off Topic 6 10-20-2007 09:19 AM
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 09:38 AM
How to remove the 3sfe from the engine bay... vuedoo Camry & Solara Lounge 40 12-17-2005 07:49 PM
Engine is back from the machine shop. Should I replace the oil pump? bennington28 Hardcore Tech and Competition 1 09-02-2003 04:01 AM
