90 LE, oill leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2007, 04:30 PM   #1 (permalink)
View Gopal's Photo Gallery
90 LE, oill leaks
My 99LE (love it!), leaks oil... a few drops overnight. I am planning to change the valve cover gasket. Is it a DIY or should I go to the mechanic? Also the gasket I bought did not have seal for spark-plug gaps, is that correct?
BTW, I had to get the harmonic balancer changed recently. It came apart.
Thanks!
Gopal
Gopal is offline   Reply With Quote
Old 08-01-2007, 08:40 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
you can do it yourself... i did it myself in about 30 mins...only 4 bolts holding it on after you take out the spark plugs yes i bought it from the dealer and it did not come with the spark plug tube seals. you should also change the spark plug tube seal.. it's like 12$ for 4.
Old 08-01-2007, 09:54 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
tighten the nuts evenly until the top of the tube goes level with the nut and black silicone all the corners
Old 08-02-2007, 09:20 AM   #4 (permalink)
Thanks... both!
So, I have to purchase the spark plug seal separately. No probs.
Fredk, What is that black silicone?
BTW, it is a 1990 and not 99LE. Typo...
Old 08-02-2007, 11:23 AM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
i like the aresol kind but the squeeze tube works just fine
Old 08-02-2007, 11:46 AM   #6 (permalink)
View wiccanferret's Photo Gallery
I use the squeeze kind...it worked well. Easy job.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 08-02-2007, 11:51 AM   #7 (permalink)
Would this be a good time to do the distributor leak too?
Quoted from fredk's thread on oil-leaks...
Originally Posted by wiccanferret
Move air hose out of the way by detaching at the throttle body.
Remove distributor cap (4 bolts)
Remove Rotor (slides off)
Remove distributor (three bolts)
There's an O-Ring on the shaft that the distributor slips onto. Peel off and replace. Put it back together.
Old 08-02-2007, 03:29 PM   #8 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
u betcha
oil leaks 1996camry 5th & 6th Generation (2002-2006 & 2007-2011) 1 02-20-2007 11:55 PM
Traction Controls on LE TCLEshovon Camry & Solara Lounge 2 10-28-2005 11:15 AM
92-96 Camry LE V6 suspension- supposed to be firmer than 4-cylinder? 93 Camry LE V6 3rd & 4th Generation (1992–1996 & 1997–2001) 6 09-20-2003 02:33 PM
Buying a 2003 corolla LE bearjc99 Archived Corolla threads 1 05-27-2003 03:54 PM
