3sfe Jumps to 4k at startup - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2007, 07:47 PM   #1 (permalink)
View Friend Of P's Photo Gallery
hi everyone,
I have a 88 3sfe camry stick shift. Recently, as soon as i start the engine in neutral or in 1st gear, the RPMs jumps to about 3k -4k RPMs...and after a few seconds, i get the smell of burning oil. it happens wether the car is hot or cold. I was thinking it thinking throttle body or MAF?
any suggestions? I hate for it to jumps that fast from a cold start.
Thanks.
Friend Of P is offline   Reply With Quote
Old 08-01-2007, 08:46 PM   #2 (permalink)
View toyomoho's Photo Gallery
Check IAC valve, might need cleaning.
Old 08-02-2007, 01:46 AM   #3 (permalink)
View scribby's Photo Gallery
Does it go away if you quickly press the acc pedal? Does it happen when you stop and start the car at normal operating tempreature?
scribby is offline   Reply With Quote
Old 08-02-2007, 04:28 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Other then the IAC, I'd also check the throttle body and give it a good cleaning with carb, fuel injection, or brake parts cleaner.
Throttle body could be sticking as a result of carbon buildup.
"Skoolin' the unlearned!"
Old 08-02-2007, 11:50 AM   #5 (permalink)
View wiccanferret's Photo Gallery
Also check your throttle cable. Mine was binding at one point causing it to do something similar. I wouldn't worry about the burning oil smell until you figure out the throttle problem...that the car is burning oil when it's revved up to 4k when it's cold is not at all surprising...or good for it.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 08-02-2007, 10:09 PM   #6 (permalink)
No, it stays the same if i tap the accel. pedal. or it will go upwards to 4k. it does the same cold or at operating temp.
I did clean the throttle body with STP throttle body cleaner. just replace the TB assembly w/ the accompanying Throttle position sensor and IAC?
any other suggestions?
Old 08-08-2007, 11:40 PM   #7 (permalink)
update:
ok, so, i tested the iac valve, and cleaned it and the throttle body with throttle body cleaner. but it did not help.
The Iac tested within specs.
the cold start injector was also within specs.
i didn't test the throttle position sensor 'cause it required tools i didn't have.
so, i just replaced the entire throttle body with the accompanying iac valve and TPS. and now, she's purring at about 700 rpm!
Thanks to all those who helped!
Old 08-09-2007, 08:38 AM   #8 (permalink)
Holy crap, how much did that cost?
Old 08-09-2007, 08:10 PM   #9 (permalink)
75 bux. cheapest i could find at dismantlers. I only called a few. not a difficult job. just getting those hoses off.
Old 08-10-2007, 08:29 AM   #10 (permalink)
$75 for the TB, IAC, and TPS? Not bad!
89 3SGE / 3SFE interghangable parts 89GTS Celica Forum 12 07-10-2006 09:24 AM
Gen2 3sfe (USDM) vs. Gen3 3sfe (JDM) - What's the Difference? airswoosh1 1st & 2nd Generation (1983–1986 & 1987-1991) 15 12-24-2005 12:10 PM
Thinking of swapping 2vzfe V6 for 3sfe I4 es250nut Camry & Solara Lounge 17 07-29-2005 09:01 AM
Old 3sfe ECU incompatible with new 3sfe? Talisman Hardcore Tech and Competition 8 05-15-2005 03:27 AM
Gen2 3SFE Knocking at Startup and Tapping Noise Above 3k RPM + Few other problems. Boostaholic 1st & 2nd Generation (1983–1986 & 1987-1991) 2 03-30-2005 06:06 PM
