The driver side power window does respond, but only if I hold the switch at full extension and for a second or so. I thought it was a contact problem so I pulled out the console and cleaned up everything. There was carbon build up which I removed. The switches for other windows now perform far better, but no change in the driver side one. Any suggestions on what I should look for?
Also, the driver side power door lock does not work, but, the unlock mechanism works.. Earlier double twisting the key used to lock the doors, but recently that too stopped. Interestingly, the unlock works here too. The passenger side one works and I am using that to lock.
I cleaned the contacts so, I do not think that is a problem.
Appreciate any suggestions.
Regards,
Gopal
PS: Ofcourse cleaning the console was a PITA and I am not looking forward to it anytime soon...
