how to test Air flow sensor Voltage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-04-2007, 09:50 PM   #1 (permalink)
View rockhard's Photo Gallery
What do I need to do/have in order to test the voltage that the air sensor sends to the computer,
I am going to swap in a MassAirFlow sensor in the place of my stock vane air flow meter, which has a metal plate inside that restricts the flow.
I need the voltage so I can find an aftermarket sensor that gives out the same voltage.
any help appreciated thanks..
rockhard is offline   Reply With Quote
Old 08-09-2007, 01:34 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I recall that there is a section in the Camry manual that explains how to troubleshoot the MAF. It measures resistance. Would that work for you?
Otherwise you could also use the manual to determine which of the MAF contacts were sending the information to the computer. Gently pry off the plastic cap and you will see how the air vane's sensor travels over an electric plate. Hook the MAF up to a battery. Hook a voltmeter up to the appropriate contact(s) and see what the voltage is at the different ranges. You might be able to determine what you need from that.
However, I'd stick with an identical replacement MAF sensor, it is also sending other info to the computer.
Kep
Any stock intake mods? t0eknee 5th & 6th Generation (2002-2006 & 2007-2011) 17 09-07-2010 06:07 PM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
Air flow problem aziandanny Camry & Solara Lounge 3 12-21-2005 08:06 PM
mass air flow sensor??? mr2trd MR2 Forum 20 10-07-2004 09:58 AM
