1990 Dome Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2007, 12:55 PM   #1 (permalink)
View wiccanferret's Photo Gallery
1990 Dome Light
Everything in the car works except for the dome light. I have checked the "Dome" fuse under the hood, and it is good. I even replaced it just in case with no luck. I wasn't able to figure out which inside fuse was related to the dome light because there's no cover on my car, so I checked them all and none of them looked busted. I replaced the bulb...duh.
What would be the next thing to check?
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 08-12-2007, 09:08 PM   #2 (permalink)
View gspservice's Photo Gallery
Check the door switch or short the door switch wire out and see if the light then works.
gspservice is offline   Reply With Quote
Old 08-12-2007, 10:10 PM   #3 (permalink)
It doesn't work even when it's set to "on." Would that make a difference?
Old 08-13-2007, 01:45 AM   #4 (permalink)
The bucket owns you!
ChevelleSSLS6's Avatar
View ChevelleSSLS6's Photo Gallery
mine doesn't work either, so I bought a flashlight.
ChevelleSSLS6 is offline   Reply With Quote
Old 08-13-2007, 08:41 AM   #5 (permalink)
Hahah, well, I'm trying to make mine into a somewhat nice family car, so a flashlight won't really help too much.
Old 08-13-2007, 08:56 AM   #6 (permalink)
NYR
View IvanHoe's Photo Gallery
the contacts on the switch of the light are no doubtably busted.....with a little patience and a soldering iron it can be fixed (common issue for these cars)....once you unscrew the light from the roof and look at the underside of it, you will see exactly what Im talking about........
the door buttons tend to get "dry" as well....with those, I pulled back the rubber and doused the contacts with WD-40
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 08-14-2007, 09:08 AM   #7 (permalink)
Okay, I'll pick up a new soldering tip on the way home and yoink the dome light when I get there. Maybe it'll be working by tomorrow...
Old 08-14-2007, 11:56 AM   #8 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
While you are in there, get a volt meter reading directly from the wires to determine that you do or don't have voltage to the switch. I never could get my switch fixed but I did have voltage so I knew to buy a replacement switch (eBay) and it worked great.
Kep
Old 08-14-2007, 01:12 PM   #9 (permalink)
Hell yeah, I actually wouldn't have thought of that. Now to buy a cheap multimeter...lol.
Old 08-17-2007, 09:21 AM   #10 (permalink)
my front passenger window doesnt work... do the switches pull out with a little screwdriver and prying, or is there a more complicated procedure with this?
-Matt
Old 08-17-2007, 12:48 PM   #11 (permalink)
Kep
Kep's Avatar
I am pretty sure that you need to remove the door panel. Check the on line manual.
Kep
Old 08-19-2007, 12:30 PM   #12 (permalink)
on line manual?
anyway I took a little flat blade screwdriver and pried around the perimeter of the switch panel and it popped out with a little coaxing. Then I seperated the panel and the switch assembly (all of the switches, even power locks, are on this) and I can't get that apart on one side... I'm looking for one on ebay at the moment, maybe it'll work better)
-Matt
p.s. all else fails, I could just jump the wires, right?
Old 08-19-2007, 05:24 PM   #13 (permalink)
View monito's Photo Gallery
Originally Posted by ChevelleSSLS6
on line manual?
http://www.camrymanuals.com/
monito is offline   Reply With Quote
Old 08-20-2007, 10:05 AM   #14 (permalink)
thanks!
-Matt the toyota noob
Dome Light Bulbs...short life span 87_SR5 Pre-88 Toyota Pickup/Hilux 4 02-12-2006 08:47 PM
Dead dome light, trunk light, clock! mwebb Camry & Solara Lounge 4 01-21-2006 04:47 PM
'90 Camry, should dome light burn when REAR doors are open? CHaynes112 1st & 2nd Generation (1983–1986 & 1987-1991) 4 02-06-2005 04:01 PM
Dome light difficulties Snip3r Archived Corolla threads 7 09-05-2004 09:19 PM
