swapping in the jdm 3sfe engine?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2007, 06:02 PM   #1 (permalink)
View blade0604's Photo Gallery
2nd Generation swapping in the jdm 3sfe engine??
hey everyone. well i have 200000 miles on my 87 carmy right now and i was gonna put a 3sgte engine in it but i found out how much of a nightmare the wireing can be so now i'm leaning towards the jdm motor.... how difficult is this engine? and how much trouble would it be to swap over to a 5 speed... ?
blade0604 is offline   Reply With Quote
Old 08-12-2007, 07:40 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
straight forward... pull your old one out put in the new one. no wirings involved. can probbly crank it out over a weekend in your garage if you have an engine puller..well for the 5spd swap you need to start collecting parts... a tranny..clutch pedal,clutch master cylinder and slave, brake pedal from a 5spd it's smaller,shift linkage, flywheel,clutch,pressure plate,clutch hardline from the master cylinder to the slave cylinder.
Old 08-12-2007, 08:09 PM   #3 (permalink)
ok cool so i don't need a new computer or anything right? or wireing harness? andhow much power does the jdm motor have over a usdm 3sfe? i knwo i have to look for the 3sfe with the square spark plug boots.. i found about 7 on ebay. what 5 speed bolts on to the jdm motor? and will stock 5 speed axels fit? sorry for all the questions... what about a wire harness for the 5 speed swap?
Old 08-13-2007, 01:18 AM   #4 (permalink)
Pochacco Owns Me
atobe's Avatar
the engine is the same you don't need new anything...well if you'r going to use your old ECU u won't get any HP gains..i don't think those ebay engines come with ecu. any I4 camry 5spd will bolt up to it from 83-02 or whenever the last year was for the 5sfe.
Old 08-14-2007, 08:53 PM   #5 (permalink)
hey guys... does the ecu off a 92- 96 camry just plug into my 87 camry? do i need to change anything? i plan on buying a jdm 3sfe engine and a new jdm transmission i guess from ebay and i was just wondering if any computer from any year would work?? i guess i'm asking do i need to nbuy a new wireharness also?
Old 08-15-2007, 11:25 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ No, No, No, and No.
If your replacing a 3S-FE with another 3S-FE, you don't need another ECU or wiring harness. Use your existing ECU and wiring harness.
3S-FE come with 6 bolt or 8 bolt crank. Make sure the engine your buying comes with the correct flexplate (automatic) or flywheel (manual) for the engine.
Use your existing manifolds and accessories. In other words remove them off your existing engine and bolt them onto the new engine.
Some of the sensors might be different, if so swap them with the ones from your existing engine.
"Skoolin' the unlearned!"
Old 08-15-2007, 11:37 AM   #7 (permalink)
Pochacco Owns Me
atobe's Avatar
if you read the warranty on the ebay engines only the long block and head is warranty to work. and nothing else, no sensors or accessory stuff.
Old 08-15-2007, 12:48 PM   #8 (permalink)
ok cool i got yall now. i might have hit a little gold and struck all the parts i need for a 5 speed swap also. i hope anyway.
Old 08-15-2007, 09:00 PM   #9 (permalink)
Grenaded piston
88 LE's Avatar
Used JDM engines usually come as long blocks (block and head). So a warranty on the long block is all you need.
Harsh 2-1 Downshift while in 'S' Mode Mistabullet 5th & 6th Generation (2002-2006 & 2007-2011) 20 03-19-2007 08:01 AM
JDM 3SGE Engine fires but doesn't run wooly55 Celica Forum 3 10-26-2006 12:34 PM
Part IV; 20R ENGINE REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 6 10-05-2006 11:28 PM
