Accessing Under-Dash A/C parts on a 91 Camry.
Hello all,
My son's AC on his 91 Camry (converted to 134a) had stopped blowing cold air and after adding the UV detector we found a leak in the compressor (green dye between all of the seams of the compressor) so we have replaced that along with the receiver/drier. I didn't replace the expansion valve since it was burried under the dash (OK and we were lazy). We evacuared the system and recharged with UV detector again and it cools down great for the first day. Overnight it is empty, so there is a substantial leak somewhere, but we can't see it anywhere under the hood with the UV light, so I assume it is under the dash at the evaporator or the expansion valve (the only parts left). How do I get access to the evaporator? I assume the glove box and all of the surrounding small under dash plastic can be easily enough removed, but how mush of the dash itself will need to be disassenbled to get at it to do an exam and replace? I don't have any of the repair manuals and can't even find anything specific to the 91 Camryanymore since it is so old, just generic info.
Any help?
Thanks
Rick
