Rough running after rain - even if not driven in rain.
Gentlemen,
My 1990 Camry wagon, 2-litre: Whe n it rains, it runs real rough until the engine warms up thoroughly.
But here's the real mystery: If it happened when driving in the rain, kicking water up onto the electrical, you'd say right away bad wires or something associated with being wet. But even if the motor is bone dry when I park it in the driveway, if it rains, it will be hard to start and run rough even though no water could possibly have speen splashed up into the motor compartment.
And here's the twist: So last night it rained after having driven the car hot and dry the day before. This morning before even starting it I pop the hood - the engine is wet!! Now, it's an old dirty engine with oil and grease here there and everywhere. And anywhere that's "dirty" is soaking wet, with the water beading up on the oil/grease. This includes the rubber boots over some electrical. What the heck? Grease that's both hydrophbic and hydrophyllic?
One such boot in particular I'm suspicious of is on the front right end of the head, just below the valve cover, near the distributor cap. A big fat rubber boot witha single skinny little wire coming out of it and going I don't know where. The boot is covered in grease and soaking wet. Is this something critical like the cam shaft position sensor and it's misbehaving when the boot is wet??
Last summer I replaced the distributor cap and all the spark plug wires to address this problem, and it appeared improved for a while. Then this summer it's gotten worse.
Any bright ideas would be welcome.
Thanks
