'87 wagon broken timing belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2007, 12:35 AM   #1 (permalink)
View stricular's Photo Gallery
So here is how it went down:
My brother was out with the wagn to go play pool or something, and he told me "the check engine ligh came on and it just died." I went over to help himout, and so first thing I checked the oil, which was pretty damn low. Next I had him crank the starter with the ditributor disconnected, and the bottom end seemed to turn over normally.
The engine, of course, wouldn't start, but it was making this squinking sort of sound from what seemed like the distributor general area.
Does this sound like the belt, or something much worse? I am going to confirm this tomorrow, but I was hoping maybe to get some input tonight so I can be prepared to fix it as fast as possible,since it looks like I will have to do it while it's parked on the street, and its not real close to our home or a parts store.
So yeah, squinky cranking=timing belt snapped? or what else?
One bright note is that we were able to push it into a legal space in an area where finding parking after dark is like a finding a glacier in the rainforest. Score!
stricular is offline   Reply With Quote
Old 08-20-2007, 12:55 AM   #2 (permalink)
View scribby's Photo Gallery
Did the rotor inside the distributer turn when you tried to crank it?
scribby is offline   Reply With Quote
Old 08-20-2007, 02:19 AM   #3 (permalink)
It was raining pretty good,
and really too dark to be messing with taking the cap off, but still I had to fight back the urge to do it. I guess I just like getting dirty, what can I tell you.
That's the first thing I intend to check tomorrow. I was just hoping maybe somebody else would post up saying, yeah I had the same thing/sound happen and it was just the belt.
I will keep you posted.
Old 08-20-2007, 08:00 AM   #4 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Pull out the code first.
To check for broken timing belt, take out the round rubber plug in upper the timing belt cover--this will expose the cam sprocket. Crank the engine and see if sprocket is spinning.
Doctor J is offline   Reply With Quote
Old 08-20-2007, 12:28 PM   #5 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Not sure what you mean by "squinky" cranking.
If the rotor turns while cranking the engine the timing belt is not broken. I think this is what you meant when you said that you disconnected the distributor and the bottom end turned but I am uncertain. If it isn't it is an easy check.
More info please.
Kep
Old 08-20-2007, 12:42 PM   #6 (permalink)
I disconnected the distributor input wires, just to avoid ignition at a potentially weird point in the juxstaposition if the cam/crank, in case the timing belt is broken and valves are stuck closed when they shouldnt be.
I am heading over to the car now. I willlet you all know what I find.
Old 08-20-2007, 12:48 PM   #7 (permalink)
one more thing
you know that video circulating the web where the guys pour water into the engine,then out pennies in the head? it sounds very familiar to the squinking sound heard in that video:
http://www.youtube.com/watch?v=UC_a9-PCwEw
Old 08-20-2007, 02:58 PM   #8 (permalink)
Update:
I pulled off the cover as suggested by Dr. J(thanks for that helpful tip!).
Camshaft sprocket no turny.
So it looks like it's the belt to me. Hopefully nothing is locked up under there(oil pump, tensioner,etc). This engine has alot of miles, so I want to minimize how much we spend on it.
That said, assuming everything under the timing belt covers is still ok, could I just buy the belt and throw it on? Or is there anything else that is essential for me to replace while I have it open? I would rather not do it twice.
Also, I like Gates brand belts, They make OEM timing belts for hondas and many other cars. Up to and including the last one I bought(for my tercel), they were made in USA. Any objections?
Thanks for the help so far, y'all. With your help, I'm sure I can get this sorted.
Old 08-20-2007, 03:12 PM   #9 (permalink)
Doctor J's Avatar
Regarding video: Instead of torturing the car they can donate it to someone who is in hardship.
check the waterpump/oil pump shaft play.
Old 08-21-2007, 01:55 PM   #10 (permalink)
Kep
Kep's Avatar
Since you have another car to run for parts, just take off the cover and check things out before you buy parts. Consider the engine seals, the water pump and maybe the oil pump. I believe that there is another belt in there to run the oil pump that you may want to replace. This is all going on memory. You may want to do a search on this site as well as check the on line manual. There are a lot of posts covering this.
One of the good things about Camrys is that they are "non-interferance" engines so breaking the timing belt doesn't damage the engine. The timing belts do deteriorate quicker if they are getting water or oil on them so if it isn't clean under the cover try to fix the leak(s) before going to the trouble of putting on the new belt and timing it.
Kep
Old 08-22-2007, 09:14 PM   #11 (permalink)
View marc780's Photo Gallery
How long are you going to keep the car? If a year or less, yeah, i would just throw a timing belt on and forget it. If you dont know how long you will have to keep it, and otherwise seems to be good (just how low was that oil? Im sure you already know thats the quickest way to kill an engine there is) - i would change the water pump, cam seal, and idler while i was in there too.
There are a couple excellent posts on changing timing belts here and it may not be the one for your exact engine but it'll be pretty close. I'd guess you'd spend about $150 - 200 for parts to do it right. A timing belt alone is about $30.
Old 08-24-2007, 01:42 PM   #12 (permalink)
Update:
So after fighting with the rain for the past few days, today I finally got the front of the motor all disassembled. I also removed the old timing belt, which, to my astonishment, WAS NOT BROKEN!
It seems some of the teeth on the belt tore off. about a 5" length is just down to the backing. Most of the broken off teeth were down towards the crank sprocket area.
So I believe what happened is that the crank sprocket started to slip, and just tore all the teeth right off the belt.
What I am not sure of, is why.
I have every reason to believe that this is the factory original timing belt, but I really have no way of knowing.
The back(flat side) is cracked and splitting around the entire circumference of the belt.
OK on to what I found under the covers.
It was surprisingly clean under the front covers. Both pumps and both idler pulleys checked out fine. I turned the head over, via the sprocket bolt, and that took a little force(especially initally, like the first nudge was tight), but I would imagine that is to be expected, what with the cams pushing on the valve springs. I dont believe it is locked up???
It looks like I will have to remove the valve cover to put the cams back in timing anyway, so I will update you all on what I find under there, good or bad.
Right now input on the belt being broken would be greatly appreciated. What do you reckon happened?
Old 08-24-2007, 01:46 PM   #13 (permalink)
one thing I should add is that the first night when the car broke down, I brought some oil and put about 1 1/2 quarts in. That brough the oil level up to just over the full mark. So I dont think it starved at any point.
I am going out to pull the a/c compressor off now(since I am gutting the a/c to make things easier and lighter), so discuss!
Old 08-24-2007, 02:33 PM   #14 (permalink)
Doctor J's Avatar
If the back smooth side of the belt is cracked it is just age /heat damage to the point of failure. Seized cam will just break the whole belt.
Old 08-24-2007, 02:59 PM   #15 (permalink)
Word up, Doc. I will order me a new belt right now. Gates, made in USA $18 from napa(never any parts available ).
Also, engine bay a/c parts fully gutted! Woot! I'll probably just leave the condenser in there for now. Every other part is up for grabs!
And yes the belt has cracks on the smooth side in between every tooth.
Just for shits and giggles, is there any way to tell if the timing belt is indeed the factory installed one?
5S-FE Timing Belt Replacement mskhan18 Camry & Solara Lounge 8 05-30-2006 11:31 AM
timing belt broken? iwannadie Supra Forum 20 11-28-2005 10:19 PM
Changine Timing Belt..Found Oil behind Timing Covers A2brb Camry & Solara Lounge 11 11-14-2005 04:10 PM
How TO Change Timing Belt on 87 celica GT?? CEOtimeccles Celica Forum 4 06-12-2004 06:51 PM
