city light problems. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2007, 11:53 PM   #1 (permalink)
View 1989PandaCamry's Photo Gallery
After trying to wire the corners into signals my city lights don't come on anymore. When i click the light switch onto the first click my corners and tail lights don't come on anymore. what happened?
signals still work though.
brian
1989PandaCamry is offline   Reply With Quote
Old 08-22-2007, 01:05 AM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
may be you blew a fuse.. does your cluster illumination turn on? and the rest of the stuff that usually turns on with the first click go on?
Old 08-22-2007, 01:17 AM   #3 (permalink)
Yeah thats what i shoulda guessed first. I thought i burned out the wires cause i've been running 55w fog light bulbs in my corners. gonna get a new fuse tomorrow. Thanks.
Old 08-22-2007, 03:34 AM   #4 (permalink)
NYR
View IvanHoe's Photo Gallery
.........probably not a good idea to run those 55w bulbs
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 08-22-2007, 09:45 PM   #5 (permalink)
why is that? i've been going for 3 months with them already.
Old 08-22-2007, 10:39 PM   #6 (permalink)
Pochacco Owns Me
atobe's Avatar
may be that's why it's broken.... that's like hooking your garden hose up to the fire hydrant it'll hold for awhile then it just blows
Old 08-23-2007, 12:03 AM   #7 (permalink)
lol well the fuse burned out when i was doing the signals. So i don't think that is why. But it is so bright and i like it.
Old 08-24-2007, 08:13 PM   #8 (permalink)
mk2-1jz's Avatar
View mk2-1jz's Photo Gallery
Hey 1989Panda can i ask you how you wired the signals to the parking lights? I'm interested in doing the same thing, havnt been able to get the wiring right though. Thanks for your help,
Jamie
mk2-1jz is offline   Reply With Quote
Old 08-24-2007, 08:22 PM   #9 (permalink)
Originally Posted by 88 LE
You have to do some cutting and splicing, but here it goes.
1. Cut the ground wire going to the corner light.
2. Tape off the end that goes to the car cos you don't need it anymore.
3. Splice the ground wire from the corner light to the +12V of the blinker. You'll need some short pieces of wire and some crimp connectors.
Make sure that you verify the wires with a DMM before you cut and splice.
Parking lights off = corner lights and blinkers blink at the same time
Parking lights on = corner lights and blinkers alternate
Old 08-27-2007, 05:30 PM   #10 (permalink)
mk2-1jz's Avatar
thanks pandacamry, I tried it and that wiring guide worked great, but i was wondering if i could just get rid of the under bumper flashers altogehter and just use the parking light bulb as the flasher/parking light. I want to put some high powered fogs in their place. I belive this is possible, but i'd rather ask before crimping and stripping wires on the car. thanks a lot, Jamie
Old 08-29-2007, 07:12 AM   #11 (permalink)
mk2-1jz's Avatar
I've been playing around with the wires and havn't yet been able to wire up just the parking lights as flashers, anybody have any ideas?
Old 08-30-2007, 01:32 AM   #12 (permalink)
Well i think if you removed the signal's wires anywhere after where you spliced the corners onto the power wire of the signal. The corners should still blink without the signals, and then you could remove the signal housing and put in some foglights.
Old 08-30-2007, 01:50 PM   #13 (permalink)
mk2-1jz's Avatar
thanks for the responce. i tried leaving the wiring as in and unplugging the turn signals, the corners stop flashing, i dont know if the wiring i did is in series or parallel, but if its paralell it needs the signals to be hooked up for it to work, i've been playing around with it but have yet to figure it out....
thanks, Jamie
Old 09-02-2007, 04:51 PM   #14 (permalink)
mk2-1jz's Avatar
2nd Generation
Does anyone have any ideas of how I can disconnect my under bumper flashers then take the wires and add them to the parking lights. I want to achieve ideally a parking light that stays on but flashes with the flashers. thanks.....
Real HID's not necessarily "better" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 26 12-11-2006 06:06 PM
97 Camry Light Problems Neileum 3rd & 4th Generation (1992–1996 & 1997–2001) 7 05-21-2006 11:15 AM
2005 Corolla S Airbag light & Fuel problems 2005corollaS Archived Corolla threads 2 03-29-2006 11:47 AM
1990 Toyota Camry Light Problems JBlack16 1st & 2nd Generation (1983–1986 & 1987-1991) 4 03-14-2006 12:59 AM
reverse light problems wormhole Camry & Solara Lounge 1 03-12-2006 04:42 PM
