You might as well remove the intake and fuel rail. I would suggest releasing the fuel pressure at the cold start injector before pulling the fuel rail.
When you pull your head, you need to pull the cams to get to the head bolts. Use a permanant marker and number the exposed shims. Then before you take your head to the machine shop remove the lifter buckets with the shims in them, they should slide right out. It would be a good idea to number the buckets too since the only thing that would be holding the shim in the bucket would be the cohesion of the oil between the bucket and shim.
When you reassemble the head you will want to put each bucket and shim in their original spots.
While your head is out replace (or have the machine shop replace) the oil seals on the valve stems too.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
