wierd exhaust question; 3sfe silent performance - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2007, 01:09 AM   #1 (permalink)
The bucket owns you!
ChevelleSSLS6's Avatar
View ChevelleSSLS6's Photo Gallery
Question wierd exhaust question; 3sfe silent performance
I assume that the bucking issue is due to the infamous ignition short in the 3sfe under the hood, so with that out of the way next project for my DD is exhaust...
the pipe is rusted through where it bends to the passenger side under the rear seats, and there's nothing there besides a blown out muffler with visible fiberglass packing hanging down looking all ghetto.
Here we have a couple of small problems...
1. it's slow. maybe it'll have more balls than a four year old girl once the bucking issue is sorted out and with fresh plugs and wires I plan on giving it while I'm at it. But I wouldn't mind a little extra oomph... is 2.25" a good size? I'm looking to maximize low end torque and response, not top end power. I normally shift around 2000rpm, and being a dd it doesn't pass 3k often at all. A little mpg would be good too, even though it doesn't use alot of fuel, every bit helps the money situation.
2. I want it to be as quiet as possible, since I tend to leave the gf's place at night, that's not good waking up her siblings, and I'm not into hearing the buzzzzz of the 3sfe @ 2000rpm (~55mph) all thirty miles home. Noise is a higher priority than power.
so... any suggestions? Would stock size exhaust be best for squeezing what low end torque is available from the little four? My idea is stock size tubing from the parts store, cut-n-clamp to stock tubing after flexpipe, and have a long-azz glasspack in there, and then some bends from the bin at the local parts store, and a stock type muffler... just in the 2.25" size rather than stock 2". Let me know if this would be good, or if it would suck.
ChevelleSSLS6 is offline   Reply With Quote
Old 08-24-2007, 11:57 AM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
2.25" is the perfect 'performance' size for the Camry. I'd vote that you get all new piping from about the firewall back bent up at an exhaust shop, and just have them put on a larger stock-like muffler. If you have a welder, it should be easy to do it otherwise yourself.
I ran a straight-through 2.25" exhaust with two resonators and a magnaflow muffler on my last Camry and it was still pretty quiet. You shouldn't need anything but the one standard muffler to keep it quiet.
If your Camry is an auto, it will never really be fast... but it can at least be peppy.
-Charlie
Old 08-27-2007, 12:24 AM   #3 (permalink)
How much did it cost you at a shop? Just wondering how much it might save me if I gather the parts (and tubing) myself, lightly clamp the pieces together, and weld it up.
Old 08-27-2007, 03:07 AM   #4 (permalink)
white90dx's Avatar
I don't remember how much it was - it was 4+ years ago. It should be $100 or less plus parts, I would think. Don't exhausts rust out all the time up there? it seems like it would be common to replace exhausts at the local muffler shop.
-Charlie
Banks Monster Exhaust SR5-2006 2nd Generation (2005+) 30 08-28-2007 06:53 PM
another exhaust question? bigdrill 2nd Generation (2005+) 13 06-28-2007 11:00 AM
3sfe stubborn exhaust nutsLet’s turn the failure into the triumph. Doctor J 1st & 2nd Generation (1983–1986 & 1987-1991) 9 04-26-2007 08:32 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
Popping Exhaust Question. modifierLE Camry & Solara Lounge 9 09-07-2005 06:59 PM
