Flywheel resurface necessary? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2007, 08:28 PM   #1 (permalink)
View charsmith's Photo Gallery
2nd Generation Flywheel resurface necessary?
Hi all, I'm newish here. I've been nursing the clutch on my 91 I4 for about a year and a half and I've decided to replace it during my manternity leave (my wife's due any minute now!). Do you have to resurface the flywheel when you replace the clutch? Is it best to replace the flywheel too? Any special tools required? Thanks for any help!
charsmith is offline   Reply With Quote
Old 08-27-2007, 08:37 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
you could if it's warped but if not then just leave it alone... would be best for a shop to do it if needed not something you can do yourself
Old 08-27-2007, 10:42 PM   #3 (permalink)
So the surface is generally ok then? I don't get any chattering or pulsing, just good old fashioned slippage.
Old 08-28-2007, 12:36 AM   #4 (permalink)
71Corolla's Avatar
Gameroom cash: $547550
View 71Corolla's Photo Gallery
Considering the labour involved in replacing the clutch, always resurface they flywheel. It is not that expensive and will ensure the new parts last and work correctly.
Make sure you replace both bearings as well. For the pilot bearing, you will need some type of puller most likely.
[edit] and don't forget to get brake cleaner to clean off the flywheel before assembly. BTW, unless the flywheel has cracks in it (it might) it can most often be resurfaced.
71Corolla is offline   Reply With Quote
Old 08-28-2007, 12:53 PM   #5 (permalink)
View toyomoho's Photo Gallery
This issue is if surface of the flywheel where the clutch plate rides is glazed, has hard spots from heat or is warped. If it is not a big deal to take the flywheel in to a shop for resurfacing, do it. It will pay off in better clutch operation and life. Otherwise you can try to break any glaze with sand paper.
Old 08-28-2007, 02:29 PM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Of course, if this is your only vehicle you are going to be in a world of hurt when your wife finds out that she can't get to the hospital until you fix the car! :-)
By the way, congratulations.
Kep
Old 08-28-2007, 05:10 PM   #7 (permalink)
Thanks everyone! I'll plan on resurfacing it while I've got things apart (I assume this is just done on a lathe).
I appreciate all your help!
Old 08-28-2007, 05:48 PM   #8 (permalink)
Find a shop that can grind the surface (the prefered method). If the flywheel has a step (not completely flat) make sure they grind both surfaces by an equal amount.
Flywheel run-out, reuse old clutch disc, tranny noise question(s) chipsndukes 1st Generation (1995.5–2004) 12 07-13-2007 03:24 PM
Flywheel bolts questions Buurin Archived Corolla threads 1 06-10-2007 12:34 AM
4 Runner Flywheel fit Camry? Donald Camry & Solara Lounge 3 01-28-2006 04:14 PM
Flywheel is wrong!!! ImageMotorsport Camry & Solara Lounge 4 10-16-2005 12:04 AM
Best way to remove crankshaft pulley nut (flywheel inspection cover?)? awmccready Camry & Solara Lounge 5 11-26-2004 11:58 AM
