Manual shifting an auto tranny? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2007, 09:54 PM   #1 (permalink)
View TweakerG's Photo Gallery
I just bought an 87 camry and it has some trans problems. Mainly it shifts into 2nd gear way too early causing really slow accelleration. I've been just shifting through l,2,d to get around it. My question, is that going to hurt anything doing it that way? I don't have the time at the moment to actually fix the problem so this seems to be working until then.
TweakerG is offline   Reply With Quote
Old 08-30-2007, 10:41 AM   #2 (permalink)
View Kingdom934's Photo Gallery
For my Gen1 camry, the '2' and 'D' selections are sluggish since it doesn't downshift anymore, lots of engine reving and what not until I get up to speed. ECT fuse keeps blowing out . It's been like that for at lease 3 years so far, just got to keep shifting it and planning ahead when tackling a hill.
Soo....I guess you could do that, but i've heard some people messing up their auto tranny...of course they did it when the tranny was actually shifting and working.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 08-30-2007, 12:16 PM   #3 (permalink)
View toyomoho's Photo Gallery
Trans shifting is controlled by electric operated valves actuated by the ECU. Could be a valve or wiring problem. If the fuse is blowing perhaps a short in the wiring or a valve is defective and drawing too much currant.
The valves should be accessible with the trans still in car. If you can find the service info you can test them. The ECU may be able to store trouble codes, if so you can check to see of any are stored, download them and localize the trouble area.
Old 08-30-2007, 01:50 PM   #4 (permalink)
Once I have the time I'm going to pull the codes from the tranny since the OD light is blinking. Until then the manual shifting seems to be working for me.
Old 08-30-2007, 06:03 PM   #5 (permalink)
View marc780's Photo Gallery
Its not going to help the trans shifting it manually. Its not good for any auto to do it too much. But sounds to me like this trans is probably pretty much shot anyway. Try a fluid change because you have nothing to lose - and if this doesnt improve operation, start looking for a transmission...maybe you can find a functional junkyard one for cheap.
Manual vs Auto MK3 orionHCCA Supra Forum 17 09-09-2007 12:11 PM
94 2wd 5 speed 22re to older auto tranny swap subliminaltrips 89-95 Toyota Pickup/Hilux 0 01-18-2006 06:46 PM
tranny swap auto - manual Horseflydf Celica Forum 2 06-21-2004 03:10 PM
Can I use 89 corolla tranny parts for manual tranny conversion for my 93? Protocold Archived Corolla threads 7 02-25-2004 06:32 PM
Manual Tranny swap for ES300 using V6 Camry Tranny??? JHolland Hardcore Tech and Competition 12 07-17-2003 08:26 AM
