How many CCAs is your battery? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2007, 10:45 AM   #1 (permalink)
The bucket owns you!
ChevelleSSLS6's Avatar
View ChevelleSSLS6's Photo Gallery
My 88 Camry (stock) has a 650cca... swapped in the 530cca that came in my Jeep when I got it and put the 650 in my Jeep... thinking being a little car it didn't need a big 650. Well it started sometimes and needed a push (or a hill) to start the rest of the time.
I swapped the 650 back in and all is well once again but damn, that's a lot of juice for a low compression, small disp. four cylinder with no real demanding electrical load to speak of (not even foglights and a higher power deck).
So, I was wondering what everyone else was running in terms of their juice boxes/batteries.
-Matt
ChevelleSSLS6 is offline   Reply With Quote
Old 09-10-2007, 01:51 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
From what I have seen, the Camry (and maybe other Toyotas?) have very sensitive starter solenoids. Mine sometimes doesn't start on the first turn of the key, even with a fairly new Group 35 battery (the big recommended size). Then I turn of a few accessories and everything works just fine. If you really care, you could probably wire in a beefy relay at the starter solenoid input to get around the problem. As it stands now, the current for that solenoid runs through the ignition switch and looses voltage on its way around the car.
-Charlie
Old 09-10-2007, 09:07 PM   #3 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
well my old battery has 720 CCA... but it just died on me so now i have 910 CCA
Old 09-12-2007, 01:56 AM   #4 (permalink)
View 1989PandaCamry's Photo Gallery
-Charlie
i did the relay. Push Start button is awesome!
1989PandaCamry is offline   Reply With Quote
Old 09-12-2007, 03:45 AM   #5 (permalink)
View nuron's Photo Gallery
How do you wire in a relay? Does anyone have a write up?
nuron is offline   Reply With Quote
Old 09-12-2007, 10:17 PM   #6 (permalink)
View 1883atlantics's Photo Gallery
What brand/size battery do you have? Is it in the engine bay or trunk?
Jeff
1883atlantics is offline   Reply With Quote
Old 09-12-2007, 10:41 PM   #7 (permalink)
Pochacco Owns Me
atobe's Avatar
it's a red top optima it's in the normal place
Old 09-13-2007, 11:13 PM   #8 (permalink)
wow i researched the red top optimas and never found the 910 figure. that's a lot of juice. are u sure that isn't cranking amps, not cold cranking amps?
Old 09-13-2007, 11:40 PM   #9 (permalink)
Pochacco Owns Me
atobe's Avatar
o you'r right it's cranking amps.... but i live in california so it's the same.. it's never 0F here.
Old 09-14-2007, 07:53 PM   #10 (permalink)
i live in arizona so our heat kills our batteries. CCA doesn't mean much to me as we rarely have a sub 30 degree morning in the winter time.
do u happen to remember what group size you bought for the optima?
jeff
Old 09-15-2007, 10:37 PM   #11 (permalink)
Pochacco Owns Me
atobe's Avatar
it saids BCI group 75/35 if that's what you'r talking about... bad thing is your battery bracket doesn't work cause it's shorter by 2 inches... so i had to zip tie it to the car
Old 09-16-2007, 03:07 AM   #12 (permalink)
Gen 2 Pimp
phat91camryLE's Avatar
View phat91camryLE's Photo Gallery
Hey Atobe,
I am looking at the Red Top Optimas. Did you get the one with the reverse terminals or what? They now come with spacers that you can use to give the battery some lift. Let me know if you have the part number because my battery just died on me due to prolonged storage.
Later,
Matt
4 cyl 1991 Camry LE ... if you own a 2nd Gen Camry talk to me about the modifications you have made or wish to make... lets help eachother out
phat91camryLE is offline   Reply With Quote
Old 09-16-2007, 10:07 AM   #13 (permalink)
I'm basically now in the market for the most powerful battery we can stuff in our engine bay. 90 camry le with the 2vz-fe engine. I had a Kinetik and it didnt fit. I would relocate to the trunk, but honestly I think I would mess something up; if there's a write up on how to do it (safely, correctly) I would try it and then just get like the biggest Kinetik or Optima I could.
So is the consensus that the Optima Red Top is the best? It still doesn't seem to fit that well from what I read here. What about the Exide Orbitals? I just barely heard of these.
Jeff
Old 09-16-2007, 06:27 PM   #14 (permalink)
Pochacco Owns Me
atobe's Avatar
matt that was the same reason my battery died... i didn't get a reverse pole one.. i had to extend the + a lil bit but that was about it... i'm fine with zip ties... it looks much cooler
model # 7586DT part# 75/35-OR i'll get you a picture later.... well the yellow top has more CCA than the red... it's rated at 900 and 1125CA... i got the red cause i have a system and it lets you run it longer w/o killing the battery than the yellow top.
Old 09-17-2007, 02:20 AM   #15 (permalink)
white90dx's Avatar
You can get a true red top Optima Group 35 (instead of the 35/75 combo that doesn't really fit) from remybattery.com
Go for it...
-Charlie
My Optima battery saga....... Remarkable 2nd Generation (2005+) 20 07-15-2007 08:49 PM
Battery dies after 3 -4 days capinoy 89-95 Toyota Pickup/Hilux 13 06-05-2007 10:37 PM
Battery Problems haux Camry & Solara Lounge 3 09-21-2006 12:48 AM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 09:21 PM
Battery ?'s 1995 camry V6 LE kenny1773 3rd & 4th Generation (1992–1996 & 1997–2001) 14 11-29-2004 03:29 PM
