actually just get a open ended 19mm wrench, and slide that under the black bracket from your picture, and use a closed ended 17mm wrench on the top bolt, make sure the direction of each wrench is for loose the bolt, then squeeze the two wrenches together, that is the best way to loose the bolt, don't rely on the mouting bracket or anythign else. do the same thing for the buttom bolts, but use the flare 17mm wrench.
and don't forget to pull your EFI fuse, otherwise, you will probably have the gasoline shooting because the fuel system is pressurized.
