91 Camry Fuel Door Release cable broke - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2007, 12:37 AM   #1 (permalink)
View grandepj's Photo Gallery
Hi, I have a 91 Camry, and the fuel door release lever just stopped working. I took out the trunk lining and was able to pop the switch by hand, so I could fill up but I would still like to fix the cable itself. I took part of the back seat and back flooring out and was able to access the cable that releases the latch, and when I pull on the cable itself it does open the door. Does this mean the the cable has just been stretched over time and needs to be replaced? If so, where's the best (read: cheapest) place I can get one, and if not, what else should I look at?
Thanks for any help
grandepj is offline   Reply With Quote
Old 09-27-2007, 01:00 AM   #2 (permalink)
View car_boy_16's Photo Gallery
You should see if the cable is actually broken or if it's just stretched. If it's streched (even if it's broken, too) then you should see if you can just do a custom re-adjusting like cut the end off the cable and re-tie it to the lever so that it's taught again. I would at least attempt to do that rather than just go out and buy a new cable when you don't really have to.
1988 Camry LE 3sfe 4A - 123k miles
...Slower than a school bus!
car_boy_16 is offline   Reply With Quote
Old 09-27-2007, 08:22 AM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Most often the cable jacket at its end breaks off. If there is enough space available you can put a splint around the cable, fabricated from metal channel that is clamped to the cable jacket with small hose clamps.
Doctor J is offline   Reply With Quote
Old 09-27-2007, 11:14 AM   #4 (permalink)
View marc780's Photo Gallery
Junkyard
Old 09-27-2007, 05:21 PM   #5 (permalink)
Thanks for the replies guys. I pulled the cable from the front seat, and it started working normally with the slack in the cable being under the driver seat as opposed to the slack being farther back. Seems kind of weird to me, but it's working so whatever... lol
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
INFO: 1996 Toyota Camry Specifications Ratko 3rd & 4th Generation (1992–1996 & 1997–2001) 22 08-08-2009 05:09 PM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
