Highway problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-29-2007, 10:20 AM   #1 (permalink)
chunkysause7's Avatar
View chunkysause7's Photo Gallery
Highway problem
I have a 1991 Camry SE (Canadian Car) with 205,000 miles on it. Now my question is when i go on the highway and get up to 60mph my car feels like its going to stall like when i try to go faster the car is like jerking back and forth.
i already changed the fuel filter and air filter on it.
Is there a way to fix this???
chunkysause7 is offline   Reply With Quote
Old 09-29-2007, 12:31 PM   #2 (permalink)
View monito's Photo Gallery
when was the last time you changed the spark plugs? that could be the culprit.
also, while you're at it, inspect the Intake hose. It may have cracks on it causing your car to not get enough air intake.
Also grab OBD codes.
monito is offline   Reply With Quote
Old 10-03-2007, 04:08 PM   #3 (permalink)
View marc780's Photo Gallery
A number of things could cause this, on a high mileage engine like this i think i'd start with a compression check. If compression is low you may just need a valve job hopefully.
If compression is good, im with the other fellow, do a complete tune up including cap, rotor and spark plugs. set the ignition timing too. If you still have the problem after all this, i'd suspect tight valves, or possibly worn out or dirty fuel injectors.
Old 10-04-2007, 03:01 PM   #4 (permalink)
Gameroom cash: $302555
Just a hunch, but I would check the fuel pressure with a pressure gage. At that mileage your fuel pump could be getting weak.
Mike
Toyota Avalon 2005 Multi-Information Display Problem? uaesolidsnake 3rd Generation (2005-2012) 7 12-26-2006 05:07 AM
Another freakin problem, help!!! abovethelaw 3rd & 4th Generation (1992–1996 & 1997–2001) 9 11-26-2006 09:54 PM
car died on highway chadi Archived Corolla threads 14 09-13-2005 10:42 AM
94 corolla electrical problem al_sniperrolla Archived Corolla threads 0 10-16-2004 10:42 AM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
