I need help with my 87 camra - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2007, 11:20 PM   #1 (permalink)
View GTO MAN's Photo Gallery
When i pull the #4 plug wire off it does not drop the rpms on #4 it is not runing right,I have changed the cap. Please help Thank you randy.
GTO MAN is offline   Reply With Quote
Old 10-02-2007, 05:28 PM   #2 (permalink)
Gameroom cash: $302555
Since the cap and wires on this car are a 1-piece unit, the only other thing elecrical it can be is the spark plug. Change it or switch it with another cylinder's plug to see if the miss moves to that other cylinder. If it does you know it is definitely that spark plug. If not and the same cylinder still does not fire, then you have to look at other possible causes. Those other causes could be a faulty fuel injector to that plug (injector itself or the wiring to it) or even a burned valve.
Do the spark plug switch or replacement first and let us know if that solves the problem.
Mike
Old 10-02-2007, 10:30 PM   #3 (permalink)
Thank you Mike I will try that my plugs are gaped at 50.
Old 10-02-2007, 11:26 PM   #4 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
is it an I4 ? i'm sure the spec gap is .044
Old 10-03-2007, 03:12 PM   #5 (permalink)
That gap does seem kind of high to me. I would check the spec with the on-line generation 2 Camry manual stickied at the top of the General Camry Discussion forum. There may also be a sticker under your hood that specifies the correct gap. That gap may be too far for the spark to jump. That could be your problem.
Mike
Old 10-03-2007, 10:42 PM   #6 (permalink)
I wont to thank you MIKE a friend of mine came over to night and we looked at the #4 wireing on the ingector. We got it on and it runs like a new car now, I wont to thank you for your info, Your friend Randy. The wire was off of it, You are the man.
Old 10-04-2007, 03:05 PM   #7 (permalink)
You're welcome. Glad I could help.
As I thought further on this, I would also change the oil, just as a precaution. A lot of that unburned fuel from when that cylinder wasn't firing was probably making it's way past the rings and down in to the crankcase. An oil change now would be good insurance.
Mike
Old 10-05-2007, 04:45 PM   #8 (permalink)
"As I thought further on this, I would also change the oil, just as a precaution. A lot of that unburned fuel from when that cylinder wasn't firing was probably making it's way past the rings and down in to the crankcase. An oil change now would be good insurance."
Ignore what I added above about the necessity for an oil change. I had a brain cramp when I wrote it. I'm so used to missfires being caused by failed ignition system components, that I was thinking along those lines. There would be no fuel entering that cylinder, since your injector's electrical connection wasn't plugged in. Sorry if I caused any confusion.
Mike
F.S. Camra stuff for sale.. Sony, Nikon, Vivitar**Great Prices** CDNVITZ Non-Automotive 1 03-20-2006 02:00 AM
87 or 89 octane bjdinnebier 1st Generation (2000–2006) 7 11-29-2005 12:33 PM
87 or 89 Octane 2AZ FE age old question JComerford 1st & 2nd Generation (1983–1986 & 1987-1991) 6 10-07-2005 12:36 PM
installation pics of 87 camry intake?? ericksonm 1st & 2nd Generation (1983–1986 & 1987-1991) 5 09-04-2004 01:21 PM
